    BSEC BME680 no IAQ output
    MJ_kio
    Re: BSEC BME680 no IAQ output
    This is my fucntion process data
        /* Check if something should be processed by BSEC */
        if (num_bsec_inputs > 0) {
            /* Set number of outputs to the size of the allocated buffer */
            /* BSEC_NUMBER_OUTPUTS to be defined */
            num_bsec_outputs = BSEC_NUMBER_OUTPUTS;
            /* Perform processing of the data by BSEC
               Note:
               * The number of outputs you get depends on what you asked for during bsec_update_subscription(). This is
                 handled under bme680_bsec_update_subscription() function in this example file.
               * The number of actual outputs that are returned is written to num_bsec_outputs. */
            bsec_status = bsec_do_steps(bsec_inputs, num_bsec_inputs, bsec_outputs, &num_bsec_outputs);
            if (bsec_status != BME680_OK) return bsec_status;
            KD_DEBUG(KD_BME680_BSEC, "num_bsec_outputs %d", num_bsec_outputs);
            /* Iterate through the outputs and extract the relevant ones. */
            for (index = 0; index < num_bsec_outputs; index++) {
                switch (bsec_outputs[index].sensor_id) {
                    case BSEC_OUTPUT_IAQ:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_IAQ");
                        iaq = bsec_outputs[index].signal;
                        iaq_accuracy = bsec_outputs[index].accuracy;
                        break;
                    case BSEC_OUTPUT_STATIC_IAQ:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_STATIC_IAQ");
                        static_iaq = bsec_outputs[index].signal;
                        static_iaq_accuracy = bsec_outputs[index].accuracy;
                        break;
                    case BSEC_OUTPUT_CO2_EQUIVALENT:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_CO2_EQUIVALENT");
                        co2_equivalent = bsec_outputs[index].signal;
                        co2_accuracy = bsec_outputs[index].accuracy;
                        break;
                    case BSEC_OUTPUT_BREATH_VOC_EQUIVALENT:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_BREATH_VOC_EQUIVALENT");
                        breath_voc_equivalent = bsec_outputs[index].signal;
                        breath_voc_accuracy = bsec_outputs[index].accuracy;
                        break;
                    case BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE");
                        temp = bsec_outputs[index].signal;
                        break;
                    case BSEC_OUTPUT_RAW_PRESSURE:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_RAW_PRESSURE");
                        raw_pressure = bsec_outputs[index].signal;
                        break;
                    case BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY");
                        humidity = bsec_outputs[index].signal;
                        break;
                    case BSEC_OUTPUT_RAW_GAS:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_RAW_GAS");
                        raw_gas = bsec_outputs[index].signal;
                        break;
                    case BSEC_OUTPUT_RAW_TEMPERATURE:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_RAW_TEMPERATURE");
                        raw_temp = bsec_outputs[index].signal;
                        break;
                    case BSEC_OUTPUT_RAW_HUMIDITY:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_RAW_HUMIDITY");
                        raw_humidity = bsec_outputs[index].signal;
                        break;
                    case BSEC_OUTPUT_COMPENSATED_GAS:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_COMPENSATED_GAS");
                        comp_gas_value = bsec_outputs[index].signal;
                        comp_gas_accuracy = bsec_outputs[index].accuracy;
                        break;
                    case BSEC_OUTPUT_GAS_PERCENTAGE:
                        KD_DEBUG(KD_BME680_BSEC, "BSEC_OUTPUT_GAS_PERCENTAGE");
                        gas_percentage = bsec_outputs[index].signal;
                        gas_percentage_acccuracy = bsec_outputs[index].accuracy;
                        break;
                    default:
                        continue;
                /* Assume that all the returned timestamps are the same */
                timestamp = bsec_outputs[index].time_stamp;
    MJ_kio
    Hi @BSTRobin ,
    This sentence is very interesting sentence : We found such as "case BSEC_OUTPUT_IAQ" .etc didn't run to assign iaq lead to IAQ output is 0 in the log.
    Could you write to me something more regarding this issue? What was its cause and how it was solved?
    MJ_kio
    Hi @BSTRobin
    Could you answer my questions above?
    Moreovere what are required compilation flags for bsec library?
    I am strunggling with constant timestamp from bsec output (01015539:D:KD_BME680_BSEC :Timestamp: 16000000) and no IAQ.
    Could you support? We want to release large product series with BME680, however it is a blocker for us now.
    MJ_kio
    Hi @BSTRobin
    I think I found root cause of showing IAQ 0, despite fact received timestamp is constant. I applied config `generic_33v_3s_4d` and I needed to commented out two `if` statements in file `bsec_integration.c` in function `bme680_bsec_read_data` (I don't think it's proper solution, does it?):
                 * Following if statements have to be fixed, this is a root cause
                /* Gas to be processed by BSEC */
                // if (bsec_process_data & BSEC_PROCESS_GAS) {
                /* Check whether gas_valid flag is set */
                // if (data.status & BME680_GASM_VALID_MSK) {
                /* Place sample into input struct */
                inputs[*num_bsec_inputs].sensor_id = BSEC_INPUT_GASRESISTOR;
                inputs[*num_bsec_inputs].signal = (float)data.gas_resistance;
                inputs[*num_bsec_inputs].time_stamp = time_stamp_trigger;
                (*num_bsec_inputs)++;
    IAQ was 0, because algorithm never receives gas resistance. Both flags are not set. When I commented behaviour is the same as in Arduino example (despite constant output timestamp in comparison to Arduino example).
    Going up `bsec_process_data` comes from `bme680_bsec_trigger_measurement` and `bsec_sensor_control`.
    I don't see where flag `BSEC_PROCESS_GAS` is set, could you point me where is it or how to use it? When is it set?
    Flag `BME680_GASM_VALID_MSK`comes directly from sensor. Why it is not set? How to set it properly?
    What I have to do to run whole framework successfuly?
    Hi MJ_kio,
    Please check our previous replies, because output order in function 'bme68x_bsec_process_data' is different from in log.
    About the new feedback, i find the two flags ing bsec_iot_example.ino:
    in ''bsec_datatypes.h"----- '#define BSEC_PROCESS_GAS (1 << (BSEC_INPUT_GASRESISTOR-1))' 'BSEC_INPUT_GASRESISTOR = 4, '
    in "bme68x_defs.h"--------'#define BME68X_GASM_VALID_MSK UINT8_C(0x20)'
    If you think the IAQ output is 0 due to these two 'if' statements are not executed, you can print some message in it by adding logs.
    Or can you change a new 680 senser to test?
