05-17-2019 03:53 PM
BSEC library comes with few config "blobs" for both 1.8V and 3.3V, but nothing in between. Thats a shame as I guess quite a lot of "single-supply" IOT devices using primary batteries + DCDC will stand right in the middle to optimize battery life while keeping the rest of the system correctly powered (1.8v is still not mainstream for radio tranceivers and sensors).
Is there a way to request additional configs from BOSCH (like 2.5V that would stand in the middle or 2.8V)?
What is the impact of using "wrong" config voltage ?
Laurent
05-17-2019 04:06 PM
05-20-2019 10:56 AM
thanks for your reply,
If I understand well, as I'm planning to use the sensor in ULP mode, the impact of using "wrong" config should be marginal, as the 5mn pace should be enough to let the chip go back to ambient temperature?
Other question regarding the config 4Days/28Days flavor: is this just the time-window accounted for min/max values or is it also impacting dynamic response (filters)?
Best regards,
Laurent
05-20-2019 12:26 PM
Indeed in ULP mode, the sensor has plenty of time to cool down to ambiant (on your PCB) temperature. The part itself will not cause heating. Temperature measumrement is always measured before gas measurement takes place.
Regarding the 4Days / 28Days options. This is the time constant of the filters that track the history of the sensor. The way to think about it is : 63% of the data older than 4 (or 28) days has been forgotten. Here are the recommendations:
Mobile device -> 4 Days
Stationary device -> 28 Days
