    BSEC2.4.0.0 Heat Profile duration
    Julien1
    I have collected data using the BME688 Development Kit with 8 BME688 sensors and then generated an algorithm for BSEC2.4.0.0 using IA Studio 2.0.0
    I used the default heat profile HP-354
    I can init BSEC Library and load algorithm file without problem but after calling bsec_sensor_control() to retrieve sensor settings, I can see that the duration of each step of heat profile are too short :
    duration: 5ms, temp: 320 C
    duration: 2ms, temp: 100 C
    duration: 10ms, temp: 100 C
    duration: 30ms, temp: 100 C
    duration: 5ms, temp: 200 C
    duration total: 77ms
    For each Step the Temperature looks correct but the duration is too short, for a total duration of 77m instead of ~10,8s
    What am I doing wrong ?
    6 REPLIES 6
    Re: BSEC2.4.0.0 Heat Profile duration
    Hi Julien1,
    Did you run official example code or the code written by yourself?
    Julien1
    I modified the bsec_iot_example code delivered with the BSEC2.4.0.0 release from 23.01.2022
    Below are my init and bsec calls functions:
    int bme68x_bsec2_lib_intf_init(struct bme68x_dev* bme68x_sensor, struct bme68x_device* bme68x_i2c_dev, store_bsec2_state _st, load_bsec2_state _ld)
        st = _st;
        ld = _ld;
        return_values_init ret = {BME68X_OK, BSEC_OK};
        bme68x_sensor->intf_ptr = (void*)bme68x_i2c_dev;
        bme68x_sensor->chip_id = 0x76;
        bme68x_sensor->intf = BME68X_I2C_INTF;
        bme68x_sensor->amb_temp = 25;
        bme68x_sensor->read = bme68x_bsec2_lib_intf_read;
        bme68x_sensor->write = bme68x_bsec2_lib_intf_write;
        bme68x_sensor->delay_us = bme68x_bsec2_lib_intf_delay_usec;
        /* Initialize bme68x API */
        ret.bme68x_status = bme68x_init(bme68x_sensor);
        if (ret.bme68x_status != BME68X_OK)
            return -1;
        /* Initialize BSEC library */
        ret.bsec_status = bsec_init();
        if (ret.bsec_status != BSEC_OK)
            return -1;
        /* Load library config, if available */
        bsec_config_len = config_load(bsec_config, sizeof(bsec_config));
        if (bsec_config_len != 0)
            ret.bsec_status = bsec_set_configuration(bsec_config, bsec_config_len, work_buffer, sizeof(work_buffer));
                return -1;
        /* Load previous library state, if available */
        bsec_state_len = state_load(bsec_state, sizeof(bsec_state));
        if (bsec_state_len != 0)
            ret.bsec_status = bsec_set_state(bsec_state, bsec_state_len, work_buffer, sizeof(work_buffer));
                return -1;
        /* Call to the function which sets the library with subscription information */
        #ifdef GAS_SCAN_MODE
        ret.bsec_status = bme68x_bsec_update_subscription(BSEC_SAMPLE_RATE_SCAN); // SCAN for Gas estimate
        #else
        ret.bsec_status = bme68x_bsec_update_subscription(BSEC_SAMPLE_RATE_LP); // Low Power (or ULP) for IAQ
        #endif
            return -1;
        memset(&sensor_settings, 0, sizeof(sensor_settings));
        opMode = sensor_settings.op_mode;
        sensor_settings.next_call = 0;
        return 0;
    void handle_bsec_calls(struct bme68x_dev* bme68x_sensor, struct bme68x_data* data, uint32_t save_intvl)
        int8_t ret_val;
        bsec_library_return_t bsec_status = BSEC_OK;
        /* get the timestamp in nanoseconds before calling bsec_sensor_control() */
        time_stamp = get_timestamp_us() * 1000;
        printk("time_stamp: %lld, next_call: %lld, diff: %lld\n",
        time_stamp/1000000, sensor_settings.next_call/1000000, (time_stamp - sensor_settings.next_call) / 1000000 );
        if(time_stamp > sensor_settings.next_call)
            /* Retrieve sensor settings to be used in this time instant by calling bsec_sensor_control */
            bsec_status = bsec_sensor_control(time_stamp, &sensor_settings);
            if (bsec_status != BSEC_OK)
                if (bsec_status < BSEC_OK)
                    printf("ERROR: bsec_sensor_control: %d\n", bsec_status);
                else
                    printf("WARNING: bsec_sensor_control: %d\n", bsec_status);
            else
                int dur_tot = 0;
                for (int i = 0; i < sensor_settings.heater_profile_len; i++)
                    printk("duration: %dms, temp: %d C\n", sensor_settings.heater_duration_profile[i], sensor_settings.heater_temperature_profile[i]);
                    dur_tot += sensor_settings.heater_duration_profile[i];
                printk("duration total: %dms\n", dur_tot);
            switch (sensor_settings.op_mode)
            case BME68X_FORCED_MODE:
                setBme68xConfigForced(&sensor_settings, bme68x_sensor);
                break;
            case BME68X_PARALLEL_MODE:
                if (opMode != sensor_settings.op_mode)
                    setBme68xConfigParallel(&sensor_settings, bme68x_sensor);
                break;
            case BME68X_SLEEP_MODE:
                    ret_val = bme68x_set_op_mode(BME68X_SLEEP_MODE, bme68x_sensor);
                    if ((ret_val == BME68X_OK) && (opMode != BME68X_SLEEP_MODE))
                        opMode = BME68X_SLEEP_MODE;
                break;
            if (sensor_settings.trigger_measurement && sensor_settings.op_mode != BME68X_SLEEP_MODE)
                nFields = 0;
                bme68x_get_data(lastOpMode, &sensor_data[0], &nFields, bme68x_sensor);
                iFields = 0;
                if(nFields)
                    do
                        nFieldsLeft = getData(data);
                        /* check for valid gas data */
                        if (data->status & BME68X_GASM_VALID_MSK)
                            if (!processData(time_stamp, data, sensor_settings.process_data))
                                return;
                    }while(nFieldsLeft);
            /* Increment sample counter */
            n_samples++;
            /* Retrieve and store state if the passed save_intvl */
            if (n_samples >= save_intvl)
                bsec_status = bsec_get_state(0, bsec_state, sizeof(bsec_state), work_buffer, sizeof(work_buffer), &bsec_state_len);
                if (bsec_status == BSEC_OK)
                    state_save(bsec_state, bsec_state_len);
                n_samples = 0;
    Julien1
    Update:
    handle_bsec_calls() is called every ~3 seconds
    I get a gas estimate output wit accuracy = 3 every ~150 seconds, is it a normal behavior ?
    Julien1
    Could you give me feedback on this ?
    How can I verify that the heat profile duration is correct ?
