03-03-2022 12:25 PM
Im using the sensor BME688 with the BME688-API but I'm not using BSEC software. When I run my device, the temperature value is two degrees above the actual temperature. What should I do to calibrate my sensor?
03-03-2022 01:14 PM
Hello NBG,
1.Did you use BME688 sensor API on github? https://github.com/BoschSensortec/BME68x-Sensor-API
2.Did you have temperature log data for actual temperature and BME688 temperature?
03-03-2022 03:21 PM
Hi BSTRobin,
1. Yes, I used the API on github.
2.Yes, I have an external thermometer, which I used to compare the values, and the result of the BME688 with my own device.
03-15-2022 08:58 AM
Hello NBG,
By comparing bme280, we found no difference of two degrees.
BME280 temperature:
BME688 temperature:
Sensor API already has temperature compensation.
10-20-2022 05:40 PM
I have three BME 688 and they all read ~2 degrees C higher at room temp. Side by side they vary by around 0.5 degree
I believe that the temperature compensation is to allow for the heater, and these are essentially non-calibrated devices. The IRR filter averages values so smooth's the values, but will do nothing for the offset.
Most Python wrappers (PI3G ) have added a temp_offset value to be subtracted ( its always high from the heater and electronics) from the API values. I hilariously tried (and failed) using ice and a boiling kettle , but you really need to compare to a calibrated thermometer across a range of temps once your device is in steady state.
