    Can not read from bmi160's fifo
    Re: Can not read from bmi160's fifo
    Hello TTN,
    1.I setup SW demo on MCU,  you could refer attachment example code to run FIFO poll read, FIFO watermark interrupt read.
    2. For how to extract sensor time in FIFO, you could refer the following driver code in BMI160 sensor API.
    static void extract_accel_header_mode(struct bmi160_sensor_data *accel_data, uint8_t *accel_length, const struct bmi160_dev *dev)
    /* Sensor time frame */
    case BMI160_FIFO_HEAD_SENSOR_TIME:
    unpack_sensortime_frame(&data_index, dev);
    break;
    * @brief This API is used to parse and store the sensor time from the
    * FIFO data in the structure instance dev.
    static void unpack_sensortime_frame(uint16_t *data_index, const struct bmi160_dev *dev)
    uint32_t sensor_time_byte3 = 0;
    uint16_t sensor_time_byte2 = 0;
    uint8_t sensor_time_byte1 = 0;
    /*Partial read, then move the data index to last data*/
    if ((*data_index + BMI160_SENSOR_TIME_LENGTH) > dev->fifo->length)
    /*Update the data index as complete*/
    *data_index = dev->fifo->length;
    else
    sensor_time_byte3 = dev->fifo->data[(*data_index) + BMI160_SENSOR_TIME_MSB_BYTE] << 16;
    sensor_time_byte2 = dev->fifo->data[(*data_index) + BMI160_SENSOR_TIME_XLSB_BYTE] << 8;
    sensor_time_byte1 = dev->fifo->data[(*data_index)];
    /* Sensor time */
    dev->fifo->sensor_time = (uint32_t)(sensor_time_byte3 | sensor_time_byte2 | sensor_time_byte1);
    *data_index = (*data_index) + BMI160_SENSOR_TIME_LENGTH;
    3.Sensor time is for last frame.
    You could refer this do calculate frame time:
    Previous frame time = dev->fifo->sensor_time*39.0625us-10000us
    TTN
    Hi Robin,
    Thanks for your reply.
    I try to read the s_spi_bmi160_sensor.fifo->sensor_time, the return is 0,
    and i check all the data in the fifo, make sure there isn't 0x44 header in the fifo.
    I not sure wheather the configration or something have problem.
    the fifo configration is the below
    /* Link the FIFO memory location */
    fifo_frame.data = FIFO_BUFF;
    fifo_frame.length = FIFO_LEN;
    fifo_frame.fifo_time_enable =BMI160_ENABLE;
    s_spi_bmi160_sensor.fifo = &fifo_frame;
    /*Enable fifo*/
    uint8_t fifo_config = BMI160_FIFO_HEADER | BMI160_FIFO_ACCEL | BMI160_FIFO_GYRO | BMI160_FIFO_TIME ;
    rslt = bmi160_set_fifo_config(fifo_config, BMI160_ENABLE, &s_spi_bmi160_sensor);
    According to the example i aslo change the config as below.
    /*Enable fifo*/
    uint8_t fifo_config = BMI160_FIFO_HEADER | BMI160_FIFO_ACCEL | BMI160_FIFO_GYRO ;
    The combation i can try of setting can't enable the sensortime in the fifo.
    Could you give some suggestion?
    TTN
    Summarize the situation,
    I porting the fifo get function to the new project.
    in the new project the bmi160_get_fifo_data() can get the sensortime ,
    which the configration had no different to the old project.(Question 1)
    so i use add the the function in to a timer, when the timer is trigger,
    the timer event will call the bmi160_get_fifo_data() , and do the ble notify job.
    It works in the frist timer event handler, the funtion get acc and gyro data ,
    s_spi_bmi160_sensor.fifo->sensor_time have a sensortime value which is not 0.
    but all the data became to 0, when the second timer event .(Question 2)
    I change the bmi160_get_fifo_data() to bmi160_get_sensor_data() in the timer event.
    after the sceond timer event the readout value are also  0.
    Even if I set the event trigger timer to once every 10 seconds.
    please give me some suggestion to findout what's wrong.
    TTN
    Hi Robin,
    All the problem seems to related to the spi doesn't work in the timer and event on our nrf52 board.
    I'll try connect to the bmi160 by other system function to get the data.
