03-27-2023 09:41 AM
I am new to the BME688 sensor and I need to help to decouple the humidity and gas measurement. When I espose the sensor to solvents (Acetone, IPA or ethanol) the humidity changes in the order of 3-5% that follow the gas concentration, especially with acetone. When I expose the sensor to water I get significant gas resistance variation. I attach the raw data extracted from the BSEC2 library for Arduino IDE 2.0.3.
How can I know if the resistance measurement is due to gas sensing and not variations in humidity and vice versa?
Thank you!
05-05-2023 11:58 AM
Hi Christoforos,
For temperature and humidity value, they has been compensated in BME68X sensor API code.
For BSEC gas output, it depends on temperature and humidity values for compensation.
