    How to give power supply the IMU sensor BMI270 and BMI088
    Deviprasad
    The IMU sensor is  working on two input voltage supply 1.Vdd - Core supply 2.Vddio - digital I/O supply.My questions are in below.
    1.Is it better to supply the Vdd and Vddio seperately from two voltage regulators?
    2.Is it better to supply the Vdd and Vddio from single voltage regulator?
    3.Which method 1 or 2 is best, to increase the accuracy of IMU sensor?
    4.What are power supply specifications(Ex: Output voltage accuracy and PSRR-power supply rejection ratio etc)?
    Hi Deviprasad,
    You can refer to the power supply description in data sheet.
    Thank you for reply.
    From the section 4.3,you mean to say that,there is no difference of sensor peroformance,if we give single supply from single voltage regulator to Vdd and Vddio or  dual supply from two voltage regulators to supply Vdd and Vddio independently.Is this right?
    Please provide the max ripple voltage(rms value)or PSRR of Input supply voltage that can be given to BMI088 and BMI270 for accurate performance of the sensor.
    Hi Deviprasad,
    Yes.
    Usually, the maximum ripple voltage needs to be less than 100mV. The smaller the ripple voltage, the better.
