    How use BME688 BSEC static library in ESP32?
    mamreza
    I am Mohammad, and recently, I have worked on a custom ESP32S3 board.
    On this board, there is a BME688 sensor to measure temperature, humidity, pressure, and gas data of an environment.
    I want to run "bsec_iot_example" project to get "IAQ" values and investigate the air quality of an environment.
    As I use an ESP32S3 board, I should do the following steps:
    Step 1: Make a new project in Espressif-IDE
    Step 2: Add "BME68x senor API" files to the project
    Step 3: Add "BSEC static library" files to the project
    Step 4: Change or edit "CMakeLists" files
    Step 5: Compile or build a project
    My problem is:
    How can I add "BME68x senor API" and "BSEC static library" to the project and how can I change or edit the "CMakeLists" files? I am so confused.
    What is the solution?
    Can you provide me a step by step guidance/approach to add these files to the project and compile it successfully?
    Thank you in advance.
    Best regards,
    Mohammad
    Hi mamreza,
    Thank for your inquiry.
    You can download BME688 BSEC package from https://www.bosch-sensortec.com/software-tools/software/bme688-software which included BME688 sensor API & example code on ESP32, you can refer to the Arduino example under the package.
