    Nicla Sense - BHI260 - physical sensor IDs for self test
    sebp
    I am calling the function bhy2_perform_self_test() of the C API using the virtual  sensor IDs of the Accelerometer, Gyrosscope and Magnetometer. The call  succeeds, but the test result returns test_status=9. It seems one has to use the BSX physical sensor IDs?
    I found this: https://github.com/BoschSensortec/BSX4-HAL-4.1NoFusion/blob/master/sensord/bsx/inc/bsx_physical_sens...
    With these IDs the self test succeed. Are these the correct IDs to use?
    Re: Nicla Sense - BHI260 - physical sensor IDs for self test
    Hi sebp,
    As you call the function bhy2_perform_self_test() to do self test, sensor ID should use BSX input physical sensor ID, not use virtual sensor ID.
    Yes, you could use them.
    kise1_off
    Hi!
    Can you share an example of a self-test code?
    It will be very helpful! Thanks!
    sebp
    I am using the Arduino IDE. Because the Arduino_BHY2 lib does not expose all functionality of the bhy2 C API and also does not give access to the bhy2_dev structure, you have to add the following code to the BoschSensortec class in BoschSensortec.h:
    public:
    bhy2_dev& dev() {return _bhy2;};
    In the setup() function of the Arduino sketch I do this:
    void setup()
    	struct bhy2_self_test_resp accel_result;
    	int err = bhy2_perform_self_test(BSX_PHYS_SENS_ID_ACCEL, &accel_result, &sensortec.dev());
    	if (err != BHY2_OK) {
    		goto Error;
    	if (accel_result.test_status != 0) {
    		goto Error;
    	set_LED_color(0xff,0xff,0); // yellow
    	return;
    Error:
    	set_LED_color(0xff,0,0);
    "sensortec" is a global variable defined by the Arduino_BHY2 lib.
