Is anyone tried how long you can record the inertial data ( and fusion ) to flash at highest rate possible ?
Accelerometer 1600hz , Gyroscope 6400hz ?
I don't know what is the proper way to transmit or store this kind of data ? I guess BT or BLE has not enough speed to transmit. Storing in a flash ? Changing the flash with bigger size ? or only USB can achive this kind of speeds ?
Hi raytrace,
You could refer another topic to set sensor ODR. https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/Nicla-Sense-ME-How-to-Change-the-Acceler...
Currently, the software does not support storing the read senor data.
