    Possible bug in BMX160 API for TAP settings?
    Hi
    I was trying to setup the TAP sensing on a BMX160 sensor, using the API from GitHub.
    I had trouble setting the sensitivity of the TAP sensing and getting a TAP  interrupt triggering on INT2. The only real difference in tap force to detect a tap, was by changing the Acc range. I'll create an issue on this if I have further issues with it.
    When I printed out the registers to ensure they are being set correctly, I saw that the TAP_INT[0] and TAP_INT[1] registers were not being updated according to my settings.
    Also the tap INT was being set on INT1 instead of INT2
    Here is my init code (without my fix):
     // --------------- Init BMX160 ---------------------
      bmi.id = BMI160_I2C_ADDR;
      bmi.interface = BMI160_I2C_INTF;
      bmi.read = I2C_0_readDataBlock;
      bmi.write = performDimWrite;
      bmi.delay_ms = delay_miliSec;
      bmm.dev_id = BMM150_DEFAULT_I2C_ADDRESS;
      bmm.intf = BMM150_I2C_INTF;
      bmm.read = bmm150_aux_read;
      bmm.write = bmm150_aux_write;
      bmm.delay_ms = delay_miliSec;
      rslt_ = bmi160_init(&bmi);
      printf("bmi160_init:%i\r\n", rslt_);
      bmi.aux_cfg.aux_i2c_addr = bmm.dev_id;
      bmi.aux_cfg.manual_enable = BMI160_ENABLE;
      bmi.aux_cfg.aux_rd_burst_len = BMI160_AUX_READ_LEN_3;
      rslt_ = bmi160_aux_init(&bmi);
      printf("bmi160_aux_init:%i\r\n", rslt_);
      rslt_ = bmm150_init(&bmm);
      printf("bmm150_init:%i\r\n", rslt_);
      //// --------------- Acc & Gryo ---------------------
      ////printf("Init:AccGyro\r\n");
      //// Configure accel and gyro sensors in normal mode
      bmi.accel_cfg.odr = BMI160_ACCEL_ODR_50HZ;
      bmi.accel_cfg.bw = BMI160_ACCEL_BW_OSR4_AVG1;
      bmi.gyro_cfg.odr = BMI160_GYRO_ODR_50HZ;
      bmi.gyro_cfg.range = BMI160_GYRO_RANGE_125_DPS;
      bmi.gyro_cfg.bw = BMI160_GYRO_BW_OSR4_MODE;
      bmi.gyro_cfg.power = BMI160_GYRO_SUSPEND_MODE;
      rslt_ = bmi160_set_sens_conf(&bmi);
      printf("bmi160_set_sens_conf:%i\r\n", rslt_);
      // Configure sensor interrupt (Data Ready)
      //printf("Init:DataReady\r\n");
      bmi_int_config.int_channel = BMI160_INT_CHANNEL_1;// Interrupt channel/pin 1
      bmi_int_config.int_type = BMI160_ACC_GYRO_DATA_RDY_INT;// Choosing Data Readay interrupt
      bmi_int_config.int_pin_settg.output_en = BMI160_ENABLE;// Enabling interrupt pins to act as output pin
      bmi_int_config.int_pin_settg.output_mode = BMI160_DISABLE;// Choosing push-pull mode for interrupt pin
      bmi_int_config.int_pin_settg.output_type = BMI160_ENABLE;// Choosing active High output
      bmi_int_config.int_pin_settg.edge_ctrl = BMI160_ENABLE;// Choosing level triggered output
      bmi_int_config.int_pin_settg.input_en = BMI160_DISABLE;// Disabling interrupt pin to act as input
      bmi_int_config.int_pin_settg.latch_dur =BMI160_LATCH_DUR_NONE;// non-latched output
      /* Set the Data Ready interrupt */
      rslt_ = bmi160_set_int_config(&bmi_int_config, &bmi); /* sensor is an instance of the structure bmi160_dev */
      printf("bmi160_set_int_config:%i\r\n", rslt_);
      // Configure sensor interrupt (Tap)
      //printf("Init:Tap\r\n");
      bmi_int_config.int_channel = BMI160_INT_CHANNEL_2;// Interrupt channel/pin 2
      /* Select the Interrupt type: Tap */
      bmi_int_config.int_type = BMI160_ACC_SINGLE_TAP_INT;// Choosing Step Detector interrupt
      bmi_int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_NONE;// non-latched output
      /* Select the Step Detector interrupt parameters, Kindly use the recommended settings for step detector */
      bmi_int_config.int_type_cfg.acc_tap_int.tap_en = BMI160_ENABLE;// 1-enable, 0-disable the detector
      bmi_int_config.int_type_cfg.acc_tap_int.tap_data_src=BMI160_ENABLE; // use pre-filter
      bmi_int_config.int_type_cfg.acc_tap_int.tap_dur = 0b001;
      bmi_int_config.int_type_cfg.acc_tap_int.tap_quiet = BMI160_DISABLE;  // 30/20ms
      bmi_int_config.int_type_cfg.acc_tap_int.tap_shock = BMI160_DISABLE;  // 50/75ms
      bmi_int_config.int_type_cfg.acc_tap_int.tap_thr = 0b11111; // 125mg/2 = 62.5mg per bit (4g range)
    Here is the code that I ran directly after this init procedure to print out the registers:
      // check if Tap INT1 is enabled
        I2C_0_readDataBlock(BMI160_I2C_ADDR, BMI160_INT_MAP_2_ADDR ,  &rslt_, 1);
        printf("IntMap2=%x\r\n", rslt_ );
        I2C_0_readDataBlock(BMI160_I2C_ADDR, BMI160_INT_MAP_1_ADDR ,  &rslt_, 1);
        printf("IntMap1=%x\r\n", rslt_ );
        I2C_0_readDataBlock(BMI160_I2C_ADDR, BMI160_INT_MAP_0_ADDR ,  &rslt_, 1);
        printf("IntMap0=%x\r\n", rslt_ );
      // check if Tap detection is enabled
        I2C_0_readDataBlock(BMI160_I2C_ADDR, BMI160_INT_ENABLE_2_ADDR ,  &rslt_, 1);
        printf("IntEn2=%x\r\n", rslt_ );
        I2C_0_readDataBlock(BMI160_I2C_ADDR, BMI160_INT_ENABLE_1_ADDR ,  &rslt_, 1);
        printf("IntEn1=%x\r\n", rslt_ );
        I2C_0_readDataBlock(BMI160_I2C_ADDR, BMI160_INT_ENABLE_0_ADDR ,  &rslt_, 1);
        printf("IntEn0=%x\r\n", rslt_ );
        I2C_0_readDataBlock(BMI160_I2C_ADDR, BMI160_INT_TAP_0_ADDR ,  &rslt_, 1);
        printf("INT_TAP[0]=%x\r\n", rslt_ );
        I2C_0_readDataBlock(BMI160_I2C_ADDR, BMI160_INT_TAP_1_ADDR ,  &rslt_, 1);
        printf("INT_TAP[1]=%x\r\n", rslt_ );
    Here is the output of the printout:
    IntMap2=0
    IntMap1=80
    IntMap0=20
    IntEn2=0
    IntEn1=10
    IntEn0=20
    INT_TAP[0]=7
    INT_TAP[1]=a
    Then I had-coded the TAP registers, by changing the TAP init sequence to the following (before the printf sequence):
      // Setup INT_TAP[0] correctly
      rslt_ = 0b00000111;
      performDimWrite(BMI160_I2C_ADDR, BMI160_INT_TAP_0_ADDR, &rslt_, 1 );
      // Setup INT_TAP[1] correctly
      rslt_ = 0b00001111;
      performDimWrite(BMI160_I2C_ADDR, BMI160_INT_TAP_1_ADDR, &rslt_, 1 );
      /* Set the Tap Detector interrupt */
      // correct INT channel for Tap. Bug in library
      // disable int1_s_tap
      rslt_ = rslt_ & 0b11011111;
      performDimWrite(BMI160_I2C_ADDR, BMI160_INT_MAP_0_ADDR, &rslt_, 1 );
      // enable int2_s_tap
      rslt_ = rslt_ | 0b00100000;
      performDimWrite(BMI160_I2C_ADDR, BMI160_INT_MAP_2_ADDR, &rslt_, 1 );
    which gave the following output:
    IntMap2=20
    IntMap1=80
    IntMap0=0
    IntEn2=0
    IntEn1=10
    IntEn0=20
    INT_TAP[0]=7
    INT_TAP[1]=f
    After hard-coding the registers, TAP sensing was generating an interrupt on INT2.
    Is there a bug in the API?
    Re: Possible bug in BMX160 API for TAP settings?
    Hi rdehart,
    I looked up the code for setting the interrupt mapping carefully. Although a bit obscure, the sensor API code seems to be correct.
    TAP[0]
    TAP duration is a parameter only used in the double-tap interrupt, therefore the value is not set in single-tap. It is normal to see a mismatch there between your setting and the readout. What is not normal, is that the reset value is 0x04 and you read out 0x07.
    TAP[1]
    TAP1 is the threshold. Default value is 0x0A, you are putting 0x1F in your data structure, but 0x0F with your direct register access.
    In all your sample code snippets so far, you seem to be missing the call to bmi160_set_int_config after filling the data structure for Tap interrupt config, is this simply the issue? If it isn't we would definitely need to see a logic analyzer trace of the bus activity to debug further.
    Hi o_o
    I added a function to print out the BMX160's registers, 1sec after init completed. This helped me to debug.
    I added bmi160_set_int_config just after the TAP config. This did help, but on its own did not solve my problem.
    What I found to be the final crucial step is the order of bmi160_set_int_config,bmi160_set_sens_conf and bmi160_set_power_mode. (I couldn't find where the GitHub README is clear on this).
    I originally had the order as follows (without bmi160_set_power_mode) - NOT WORKING:
    1. bmi160_init
    2. bmi160_set_sens_conf
    3. bmi160_set_int_config
    The registers were set correctly when I added (bmi160_set_power_mode) and set the order as follows - WORKING:
    1. bmi160_init
    2. bmi160_set_int_config
    3. bmi160_set_sens_conf
    4. bmi160_set_power_mode
    For those who need a guide, here is what my init code looks like:
    struct bmi160_dev bmi;
    bmi.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
    bmi.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
    struct bmi160_int_settg bmi_int_config;
    bmi_int_config.int_type = BMI160_ACC_GYRO_DATA_RDY_INT;// Choosing Data Ready interrupt
    // bmi_int_config.int_type_cfg.acc_tap_int.tap_dur = 1; // not applicable to single tap
    bmi_int_config.int_type_cfg.acc_tap_int.tap_thr = 0b00001; // 125mg/2 = 62.5mg per bit (4g range)
    /*  Set the Power mode  */
    rslt_ = bmi160_set_power_mode(&bmi);
    printf("bmi160_set_power_mode:%i\r\n", rslt_);
     Thanks for the help o_o
