2 weeks ago
I'm trying to enable continuous mode in BM688 via nordic controller. But i can't able to achieve it . Can anyone suggest on how to enable continuous mode whichof 1HZ sample rate for testing purpose?
Wednesday
Hi Mukesh_1603,
Thank for your inquiry.
We do not recommend using continuous mode in the final product. If you need to record data or do tests, you can use the continuous mode. When the temperature exceeds 60°, you must stop using it to prevent the chip from burning out at a higher temperature.
