    bme688 to get iaq, if I need to keep the sensor working continuously?
    yang2024
     1、If I want to obtain IAQ values through the library, do I have to keep the sensor working continuously? Do I need to restart calibration if there is a power outage?How to improve the speed of calibration?
    2、How long does it take for sensor calibration in LP mode?
    3、Will the self increasing overflow of timestamp values input to the library starting from 0 affect the iteration of IAQ values。
    Hi yang2024,
    1. Before powering off, the BSEC status can be saved, and the BSEC status can be loaded after the next startup.
    2. Please refer to the description on the BSEC integration documentation.
    3. You can use the RTC time of the host, which will not overflow.
    Thank you for your reply。
    1、If the BSEC library works in LP mode, Configuration for BSEC is bme688_sel_33v_3s_4d,is it necessary to give the algorithm library raw data every 3 seconds?
    2、Does the time given to the library have to be in the nanosecond range? Is RTC time in seconds usable
    3、If I want to detect the smoke on fire, is IAQ feasible?
    Hi yang2024,
    1.Yes.
    2.RTC can provide a time T of ms level. Multiplying T by 1000 can provide timestamps at the microsecond level, and multiplying T by 1000000 can provide timestamps at the nanosecond level. This method of providing timestamps allows BSEC to function properly.
    3.We haven't do this test, you can test it on your side.
