    bmi08a_write_feature_config question
    Guest
    hi!
    i load config file success(the BMI08_REG_ACCEL_INTERNAL_STAT is 0x01)
    then i read the FEATURE_CFG REG in bmi08a_write_feature_config()
    i use sync function reg_addr is 0x02 reg_len is 1,so i need read 6byte data in FEATURE_CFG
    data is: 0x80 0x2e 0x18 0x00 0x80 0x2e ,then i fix last two data => 0x02 0x00 and write in the FEATURE_CFG
    but i can't read right data in GP0 GP4,and i find ACC_INT_STAT_0 is always 0 that means no sync data ready.
    is it FEATURE_CFG read data wrong?
    thank!
    Hi Guest,
    Could we know why do you need to read the configuration file and modify it?
    hi BSTRobin !
    because bmio8x api do that
    now i can successful use sync data function, i suggest you add a NOTE in sync data example,that is :
    except for config acc int input in int1/int2 and config gyro drdy int output in int3/int4,user MUST config sync data rdy int in int1/int2
    without this config,GP0 GP4 never return value.
    and i still have a question: in the mm feature manual(an000.pdf),i see a part named AUX,and i find that is a MAG,also i can read the aux_dev_id=0x20,which is match in the pdf,so i try to set aux to data mode and read R X Y Z(HA HA,R is obviously the MAG axis strength) but the readout data seems invalid,the <BMI088 - MM Feature Set Application Note>say that also have register to config AUX output data rate,i want to know how to use aux part,or this part isn't open to outside?
    thank you for your reply~
    Hi Guest,
    Thank for your suggestion.
    BMI08x didn't support AUX interface to access Mag sensor.
