    bmi160 tap detection
    Gideon
    Long-established Member
    Dear
    I am trying to see the tap interrupt(Single and Double). It seems that it doesn't work properly even single tap detection.
    Please, review what I enabled and configured the registers for tap sensing. The file attached.
    Hello Gideon,
    TAP feature needed high ODR, you could set ODR to 200 Hz and test it again.
    Gideon
    Thanks for your help.
    Could you let me get the best configuration values for double tap?
    Here are settings that I evaluated but it is hard to see double tap interrupt.
    Sometimes, the double tap interrupt occurs but not every time.
    int_config.int_channel = BMI160_INT_CHANNEL_2;// Interrupt channel/pin 1
    int_config.int_type = BMI160_ACC_DOUBLE_TAP_INT;// Choosing Any motion interrupt
    int_config.int_pin_settg.output_mode = BMI160_DISABLE;// Choosing Open drain for interrupt pin
    // int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_80_MILLI_SEC;// non-latched output
    // int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_160_MILLI_SEC;
    int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_10_MILLI_SEC;
    // Configure accel and gyro sensors in normal mode
    sensor.accel_cfg.odr = BMI160_ACCEL_ODR_200HZ;
    sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
    sensor.gyro_cfg.odr = BMI160_GYRO_ODR_50HZ;
    sensor.gyro_cfg.range = BMI160_GYRO_RANGE_125_DPS;
    sensor.gyro_cfg.power = BMI160_GYRO_SUSPEND_MODE;
    /* Set the Power mode */
    rslt = bmi160_set_power_mode(&sensor);
    /* Select the Any-motion interrupt parameters */
    int_config.int_type_cfg.acc_tap_int.tap_thr = 4; // 62.5mg * val for 2g
    // 125mg * val for 4g
    int_config.int_type_cfg.acc_tap_int.tap_shock = BMI160_DISABLE; // 0 : 50ms / 1 : 75ms
    int_config.int_type_cfg.acc_tap_int.tap_quiet = BMI160_DISABLE; // 0 : 30ms / 1 : 20ms
    int_config.int_type_cfg.acc_tap_int.tap_data_src=BMI160_DISABLE; // filtered or pre-filtered
    int_config.int_type_cfg.acc_tap_int.tap_dur = 3; //0:50ms, 1:100ms, 2:150ms, 3:200ms, 4:250ms....
    int_config.int_type_cfg.acc_tap_int.tap_en = BMI160_ENABLE;
    Hello Gideon,
    Here is BMI160 double TAP code for your reference.
    int8_t rslt = BMI160_OK;
    int_config.int_pin_settg.output_type = BMI160_ENABLE;// Choosing active high output
    int_config.int_pin_settg.edge_ctrl = BMI160_DISABLE;// Choosing edge triggered output
    int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_80_MILLI_SEC;// latched output
    /* Select the Flat interrupt parameters */
    int_config.int_type_cfg.acc_tap_int.tap_en = BMI160_ENABLE;//tap enable, 1 - enable, 0 - disable
    int_config.int_type_cfg.acc_tap_int.tap_data_src=BMI160_ENABLE;//data source 0- filter & 1 pre-filter
    /*tap duration, select the length of the time window for the second shock event for double tap detection,
    000 - 50ms, 001 - 100ms, 010 - 150ms, 011 - 200ms, 100 - 250ms, 101 - 375ms, 110 - 500ms, 111 - 700ms*/
    int_config.int_type_cfg.acc_tap_int.tap_dur = 2;
    int_config.int_type_cfg.acc_tap_int.tap_quiet = BMI160_DISABLE;//tap quiet, 0 - 30ms, 1 - 20ms
    int_config.int_type_cfg.acc_tap_int.tap_shock = BMI160_DISABLE;//tap shock duration, 0 - 50ms, 1 - 75ms
    int_config.int_type_cfg.acc_tap_int.tap_thr = 2;//tap threshold
    /* Set the Flat interrupt */
    rslt = bmi160_set_int_config(&int_config, dev); /* sensor is an instance of the structure bmi160_dev */
    Gideon
    Thanks a lot.
