    unexpected terminal output for AN BMF055 example project-data stream
    Re: unexpected terminal output for AN BMF055 example project-data stream
    it seems doesn't work by changing the baud rate in the app. The sensor data didn't appear on the terminal window.
    The problem is solved by changing the usb-uart mode. The usb-uart was set at usb-232 mode and the terminal output is abnormal. Now the usb-uart is set at usb-ttl mode and the terminal output is right as the application note says.
    Thanks for coming back with the answer ! Indeed the BMF055 output is 3.3V CMOS output, not true RS-232.
