09-29-2022 11:29 AM - edited 09-29-2022 12:12 PM
Hi Team,
I am working with BHI160B imu and reading orientation data continuously for our application using STM32-L053R8.
Along with orientation data, we also read the Accuracy of measurement. But when I read the calibration status(Accuracy of measurement), It got fluctuated between 3 (calibrated) and other values. worrying about the data captured when status(Accuracy of measurement) got fluctuated.
Clarification Required:
Are BHI160B calibrators always-on by design -(calibration will always run in the background)? or
Do I need to re-calibrate again everytime? If yes, Could you please recommend some workaround to avoid frequent re-callibration?
Any help would be very thankful
10-04-2022 04:58 PM - edited 10-04-2022 05:00 PM
Hi vamshi,
1. Calibration algorithm is always running in the background.
2. You could refer BHI160B github calibration example to do calibration, read profile, write profile. https://github.com/BoschSensortec/BHy1_driver_and_MCU_solution/blob/master/examples/calib_profile_ex...
3. How about your test environment as your calibration status got fluctuated between 3 (calibrated) and other values?
10-06-2022 08:29 AM
Thank you for the reply @BSTRobin,
1. Okay
2. Yes I have tested the calibration status and read the data with the example https://github.com/BoschSensortec/BHy1_driver_and_MCU_solution/blob/master/examples/calib_profile_ex...
3.
3a. Present we are using the below matrix for Setting orientation. The attached image is the Orientation of the BHI160B IMU custom board which is being used for our testing. We've set Acc, Gyro, Mag orientation & testing IMU with the same attached image orientation.
int8_t bhy_mapping_matrix_config[3 * 3] = { -1, 0, 0, 0, 0, -1, 0, 1, 0 };
int8_t mag_mapping_matrix_config[3 * 3] = { -1, 0, 0, 0, 0, 1, 0, -1, 0 };
Will the IMU Orientation affect the calibration status accuracy?
3b. When we test IMU every time, we are making sure that there are no Magnetic and Electrical effects surrounding it.
11-25-2022 07:46 AM
Hi vamshi,
We don't understand how your target coordinate system x, y, z points in space. Can you describe it again?
