12-05-2023 09:21 PM
Hello, I am currently attempting to extract data from the accelerometer. The raw data shows this and I cannot find scaling factors from datasheet Table 93. Is there a way to change acceleration to m^2/s?
12-27-2023 10:15 AM
Hi Newguy,
If a sensor is opened as a wakeup sensor, then it is allowed to interrupt the host, either when each sample is available or after the maximum report latency. If opened as a non-wakeup sensor, then they must not interrupt the host.
Yes, you can use linear acceleration virtual sensor ID.
12-27-2023 06:03 PM
Ok, thanks again.
