    BME280 Forced Mode Configuration
    selmanonal
    Regarding with the interface BME280 in forced mode, I need help about how to configure settings and how to read data in a minute?
    In my work, I can interface the sensor in Normal Mode properly with the Bosh Sensortech API, but I don't know what the configure settins should be and how to get data?
    Here is my sample main.c in normal mode:
    rslt = bme280_interface_selection(&dev, BME280_I2C_INTF);
    bme280_error_codes_print_result("bme280_interface_selection", rslt);
    rslt = bme280_init(&dev);
    bme280_error_codes_print_result("bme280_init", rslt);
    /* Always read the current settings before writing, especially when all the configuration is not modified */
    rslt = bme280_get_sensor_settings(&settings, &dev);
    bme280_error_codes_print_result("bme280_get_sensor_settings", rslt);
    /* Configuring the over-sampling rate, filter coefficient and standby time */
    /* Overwrite the desired settings */
    settings.filter = BME280_FILTER_COEFF_OFF;
    /* Over-sampling rate for humidity, temperature and pressure */
    settings.osr_h = BME280_OVERSAMPLING_1X;
    settings.osr_p = BME280_OVERSAMPLING_1X;
    settings.osr_t = BME280_OVERSAMPLING_1X;
    /* Setting the standby time */
    settings.standby_time = BME280_STANDBY_TIME_1000_MS;
    rslt = bme280_set_sensor_settings(BME280_SEL_ALL_SETTINGS, &settings, &dev);
    bme280_error_codes_print_result("bme280_set_sensor_settings", rslt);
    /* Always set the power mode after setting the configuration */
    rslt = bme280_set_sensor_mode(BME280_POWERMODE_NORMAL, &dev);
    bme280_error_codes_print_result("bme280_set_power_mode", rslt);
    /* Calculate measurement time in microseconds */
    rslt = bme280_cal_meas_delay(&period, &settings);
    bme280_error_codes_print_result("bme280_cal_meas_delay", rslt);
    /* Getting the data */
    /* Humidity */
    rslt = get_humidity(period, &dev);
    bme280_error_codes_print_result("get_humidity", rslt);
    /* Pressure */
    rslt = get_pressure(period, &dev);
    bme280_error_codes_print_result("get_pressure", rslt);
    /* Temperature */
    rslt = get_temperature(period, &dev);
    bme280_error_codes_print_result("get_temperature", rslt);
    NOTES:
    I am using Nuvoton MCU.
    Interface with I2C.
    Hi selmanonal,
    You can refer to attached BME280 example code on STM32 and sensor API https://github.com/boschsensortec/BME280_driver.
