02-02-2021 03:38 PM
We need the BSEC library for BME680 on PIC32MM0064GPM028 microcontroller working on X32 compiler in MPLABx environment. I understand that you provided the library for PICMX , but it doesn’t seem to work for PICMM.
We are going to buy a large amount of BME680 if we were able to integrate it in PICMM. I dont think I would be able to use without BSEC because the other driver doesnt include the IAQ reading which is critical for our application.
thank you
02-02-2021 04:45 PM
Hello GeorgeH,
Could you compile it successfully? You could test it first.
02-04-2021 09:47 AM
Thank you for your reply. I couldn't compile it successfully it kept showing errors, if you have instructions to use the library on Mplab you could perhaps send it and I would surely give it another try .
02-04-2021 10:15 AM
Hello GeorgeH,
If the library didn't match your compile einvironment, you could please visit https://www.bosch-sensortec.com/about-us/contact/contact-form, and use the contact form to submit your request.
02-09-2021 03:40 PM
I followed your advice and used the contact form , I got no response till now. How long does it usually take to get a reply?
Thank you in advance
