    BME680 BSEC library needed for PIC32MM0064GPM028
    GeorgeH
    We need the BSEC library for BME680 on  PIC32MM0064GPM028 microcontroller working on X32 compiler in MPLABx environment. I understand that you provided the library for PICMX , but it doesn’t seem to work for PICMM.
    We are going to buy a  large amount of BME680  if we were able to integrate it in PICMM. I dont think I would be able to use without BSEC because the other driver doesnt include the IAQ reading which is critical for our application.
    thank you
    9 REPLIES 9
    Hello GeorgeH,
    Could you compile it successfully? You could test it first.
    Thank you for your reply. I couldn't compile it successfully it kept showing errors, if you have instructions to use the library on Mplab you could perhaps send it and I would surely give it another try .
    Hello GeorgeH,
    If the library didn't match your compile einvironment, you could please visit https://www.bosch-sensortec.com/about-us/contact/contact-form, and use the contact form to submit your request.
    I followed your advice and used the contact form , I got no response till now. How long does it usually take to get a  reply?
    Thank you in advance
