We need the BSEC library for BME680 on PIC32MM0064GPM028 microcontroller working on X32 compiler in MPLABx environment. I understand that you provided the library for PICMX , but it doesn’t seem to work for PICMM.
We are going to buy a large amount of BME680 if we were able to integrate it in PICMM. I dont think I would be able to use without BSEC because the other driver doesnt include the IAQ reading which is critical for our application.
thank you
Hello GeorgeH,
Could you compile it successfully? You could test it first.
Thank you for your reply. I couldn't compile it successfully it kept showing errors, if you have instructions to use the library on Mplab you could perhaps send it and I would surely give it another try .
Hello GeorgeH,
If the library didn't match your compile einvironment, you could please visit https://www.bosch-sensortec.com/about-us/contact/contact-form, and use the contact form to submit your request.
I followed your advice and used the contact form , I got no response till now. How long does it usually take to get a reply?
Thank you in advance
