Hi everyone,
I implemented code to read T/P/H and gas resistance including basic compensation based on the Bosch reference code. To measure gas resistance, we have to set specific temperature and heating time. My question is: what are the recommended values and how do they affect the results?
To clarify, I know about the BSEC library, and I already tried using it in my project. But I also want to understand how to make basic gas resistance measurements in case I don't need the features provided by the library.
Hello gbeloev,
At present, we provide BSEC algorithm library and do not disclose how it is implemented.
You could develop your own products based on BSEC.
Thanks. I am not asking about IAQ, eCO2, or any other calculated values, the calculation of which is apparently proprietary. All I am asking about is gas resistance measurement. This is documented in the data sheet and exposed in the open-source API, what's missing is just some recommendations on usage. Are these proprietary as well?
-- Georgi
Hello gbeloev,
Currently, gas registance as raw values are transformed to an index for air quality(IAQ) by smart algorithm inside BSEC. There are no other usage examples.
