    BME680 always results in BME680_W_NO_NEW_DATA
    mayor
    Re: PleaRe: BME680 always results in BME680_W_NO_NEW_DATA
    I made a simpler test case which highlighted a stupid error on my part when writing to registers. That is fixed, but now I need to see why the self-test fails here:
        if ((data[0].humidity < MIN_HUMIDITY) || (data[0].humidity > MAX_HUMIDITY))
            self_test_failed++;
    and for each entry here:
        for (i = 0; i < n_meas; i++) /* Every gas measurement should be valid */
            if (!(data[i].status & BME680_GASM_VALID_MSK))
                self_test_failed++;
    as well as:
        if ((cent_res * 5) < 6)
            self_test_failed++;
    in
    analyze_sensor_data()
    Any pointers appreciated...
    Vincent
    In the register map you showed here,  the humidity config  in register 0x72 is 0 means humidity measurement is skipped.
    Please double check at your side after you fix I2C write issue.
    In the code,  it is not set as 0.
    also the heat profile setting for gas measurement in provided register map is also wrong.
    So,  can you give me an update register map here for double confirm if all settings write to sensor is correct?
    mayor
    Hi Vincent,
    so after this bit of code:
        sensor.tph_sett.os_hum = BME680_OS_2X;
        sensor.tph_sett.os_pres = BME680_OS_4X;
        sensor.tph_sett.os_temp = BME680_OS_8X;
        sensor.tph_sett.filter = BME680_FILTER_SIZE_3;
        sensor.gas_sett.run_gas = BME680_ENABLE_GAS_MEAS;
        sensor.gas_sett.heatr_temp = 300; /* degree Celsius */
        sensor.gas_sett.heatr_dur = 150; /* milliseconds */
        /* Select the power mode */
        sensor.power_mode = BME680_FORCED_MODE;
           | BME680_GAS_SENSOR_SEL;
        bme680_set_sensor_settings(set_required_settings,&sensor);
    Reading the registers should return corresponding values, right? I'll troubleshoot that once you confirm this is correct.
    Vincent
    Yes, after bme680_set_sensor_settings,  all coresponding settings should be write into registery correctly.
    You can check there.
    But in the Github code,  there is also some other functions before set setting like bme680_get_profile_dur,  why i didn't see it in your code screen shot?  Did you delete them?
    mayor
    No, I omitted them for brevity, but it goes like:
    sensor.intf = BME680_I2C_INTF;
    sensor.read = (bme680_com_fptr_t)read;
    sensor.write = (bme680_com_fptr_t)write;
    sensor.delay_ms = (bme680_delay_fptr_t)user_delay_ms;
    sensor.amb_temp = 22;
    bme680_init(&sensor);
