    BMI323 no interrupt when FIFO and TAP occurs at the same time
    Sunil_googly
    Hi
    I am using BMI323 for getting accelerometer FIFO and tap events.
    I configured BMI323 interrupts as edge-triggered and enabled
    FIFO watermark and Tap interrupts.
    I observed that when both interrupts coincide, the host
    is not getting the interrupts, but in the INT1 or INT2 status register,
    the corresponding event bit is high. If I manually read the status
    register then interrupts start working.
    When tested individually the tap or FIFO watermark interrupt works
    properly.
    How do I get both FIFO and tap interrupts at the same time?
    I2C
    00: 1143
    01: 0000
    02: 00e0
    03: fe56
    04: 00dd
    05: 0fb8
    06: ffff
    07: fff5
    08: 0000
    09: 1539
    0a: 5331
    0b: 0023
    0c: 0000
    0d: 4100
    0e: 0000
    0f: 0000
    10: 3000
    11: 0001
    12: 012c
    13: 0000
    14: 0002
    15: 03f6
    16: fe3a
    17: 0000
    18: 0000
    19: 0000
    1a: 0000
    1b: 0000
    1c: 0000
    1d: 0000
    1e: 0000
    1f: 0000
    20: 402a
    21: 404a
    22: 0000
    23: 0000
    24: 0000
    25: 0000
    26: 0000
    27: 0000
    28: 3206
    29: 1206
    2a: 0000
    2b: 0000
    2c: 0000
    2d: 0000
    2e: 0000
    2f: 0000
    30: 0000
    31: 0000
    32: 0000
    33: 0000
    34: 0000
    35: 00b4
    36: 0600
    37: 0000
    38: 0006
    39: 0001
    3a: 0000
    3b: 1001
    3c: 0000
    3d: 0000
    3e: 0000
    3f: 0000
    40: 0001
    41: 001e
    42: 0000
    43: 0002
    44: 0000
    45: 0001
    46: 0000
    47: 0008
    48: d6a1
    49: 0012
    spi
    00: 1143
    01: 0000
    02: 00e0
    03: 0084
    04: 0097
    05: 1013
    06: fffd
    07: fffe
    08: 0001
    09: 14f1
    0a: de0f
    0b: 001d
    0c: 0000
    0d: 0000
    0e: 4100
    0f: 0000
    10: 3000
    11: 0001
    12: 012c
    13: 0000
    14: 0002
    15: 03f6
    16: 005f
    17: 0000
    18: 0000
    19: 0000
    1a: 0000
    1b: 0000
    1c: 0000
    1d: 0000
    1e: 0000
    1f: 0000
    20: 402a
    21: 404a
    22: 0000
    23: 0000
    24: 0000
    25: 0000
    26: 0000
    27: 0000
    28: 3206
    29: 1206
    2a: 0000
    2b: 0000
    2c: 0000
    2d: 0000
    2e: 0000
    2f: 0000
    30: 0000
    31: 0000
    32: 0000
    33: 0000
    34: 0000
    35: 0078
    36: 0600
    37: 0000
    38: 0500
    39: 0000
    3a: 0000
    3b: 2002
    3c: 0000
    3d: 0000
    3e: 0000
    3f: 0000
    40: 0001
    41: 001e
    42: 0000
    43: 0002
    44: 0000
    45: 0001
    46: 0000
    47: 0008
    48: d6a1
    49: 0012
    7 REPLIES 7
    Hi Sunil_googly,
    I upload exampel code on STM32 for your reference. Based on Github's BMI323 sensor API & example code(https://github.com/boschsensortec/BMI323-Sensor-API), you should define a global variable before you call bmi323_map_interrupt() fucntion to map interrupt TAP and FIFO watermark.
    struct bmi3_map_int bmi323_map_int = { 0 };
    int8_t Open_BMI323_TAP(struct bmi3_dev *dev)
    bmi323_map_int.tap_out = BMI3_INT1;
    /* Map the feature interrupt for tap interrupt. */
    rslt = bmi323_map_interrupt(bmi323_map_int, dev);
    int8_t Open_BMI323_FIFO(struct bmi3_dev *dev)
    /* Map the interrupt configuration */
    Hi BSTRobin,
    Thank you for your response.
    I have configured both Tap and FIFO watermark interrupts, but the issue I'm facing is that I am not receiving interrupts when I tap the device while the FIFO watermark is active. I am checking the INT1 status register and reading the FIFO data in the interrupt handler.
    I have configured the Accelerometer and Gyroscope Output Data Rate (ODR) to 400Hz, enabled the FIFO watermark at 5 frames, and also enabled Tap interrupts. Currently, I am receiving watermark interrupts every 5 frames. However, as soon as I tap the device, the FIFO watermark and Tap interrupts cease to occur.
    When the device stops giving interrupts, the FIFO length reaches 0x3f6, and if I manually read the FIFO_DATA, then the interrupts restart. However, after some time, they get stuck again when I tap the device. Since there is no interrupt, I am unable to read FIFO data in IRQ handler. I observed this issue when BMI323 is interfaced with I2C and the interrupt is configured as an edge trigger.
    Is there anything you can suggest to resolve this issue?
    Hi Sunil_googly,
    As you set 400 Hz ODR and FIFO watermark at 5 frames, FIFO watermark interrupt will occur every 12.5 ms, FIFO length should be 60 bytes(headless mode, 12*5 frames = 60 bytes).
    When FIFO length reaches 0x3f6, it indicates that the interrupt handler on the host side did not respond in a timely manner, resulting in FIFO not being read in a timely manner and the interrupt being suspended.
    As you have set a high ODR and a small FIFO watermark level, you need to ensure that the host can respond to interrupt programs in a timely manner.
    Hi BSTRobin,
    I tested by setting 400 Hz ODR and FIFO watermark at higher number for example 100 frames (Accelero and Gyro) samples which is of 600 words and 150 frames (Accelero and Gyro) samples which is of 900 words with Tap interrupt enabled but in these cases also as soon as I tap the device, the FIFO watermark and Tap interrupts stops.
    If I reduce the ODR then I am able to get all the Fifo watermark and Tap interrupts.
    If I test only FIFO watermark at 400hz or higher then there is no problem I am getting continous interrupts when FIFO hits watermark.
    If I test only Tap then there is no problem continously I am getting interrupt when I tap the device.
    The interrupt stops only when FIFO is running and if Tap interrupt occurs, I don't know whether it is due to BMI323 or host.
    If host misses processing of watermark interrupt then FIFO reaches to FULL is there any way to configure FIFO overflow interrupt?
