10-16-2023 11:05 AM - edited 10-16-2023 11:28 AM
Hi, by using static address, I tried to read the chip ID and rev ID.
But I found out the read command will work if I response with Ack every read.
But specification shows that every read should be followed by T-bit.
The command started with 0x7E, so I assume it is in I3C mode.
Do I miss anything?
11-17-2023 06:57 AM
Hi choongay,
Ok, got it.
If any questions, you can also let us know.
