    BSEC + DevKit + BME688: Odd Gas Resistance Values
    Re: BSEC + DevKit + BME688: Odd Gas Resistance Values
    Hi ilcnet,
    Could you give feedback?
    ilcnet
    Hello dear BSTRobin
    Yes of course, i submit code in a few hours later, thanks
    Hi ilcnet,
    We haven't found your code.
    ilcnet
    Hello dear BSTRobin this is my used code that my sensors after sensing dirty air shows me reverse values unfortunately
    #include <HTTP_Method.h>
    #include <Uri.h>
    #include <WebServer.h>
    #include <WiFi.h>
    #include <WiFiAP.h>
    #include <WiFiClient.h>
    #include <WiFiGeneric.h>
    #include <WiFiMulti.h>
    #include <WiFiScan.h>
    #include <WiFiServer.h>
    #include <WiFiSTA.h>
    #include <WiFiType.h>
    #include <WiFiUdp.h>
    #include <Wire.h>
    #include <Adafruit_SSD1306.h>
    #include "bsec.h"
    #define SEALEVELPRESSURE_HPA (1013.25)
    Bsec iaqSensor;
    String output;
    void checkIaqSensorStatus(void);
    void errLeds(void);
    float temperature;
    float humidity;
    float pressure;
    float IAQ;
    float carbon;
    float VOC;
    const char* IAQsts;
    Adafruit_SSD1306 display = Adafruit_SSD1306(128, 32, &Wire);
    // Replace with your network credentials
    const char* ssid = "***"; // Enter SSID here
    const char* password = "***"; //Enter Password here
    WebServer server(80);
    void setup() {
    // put your setup code here, to run once:
    Serial.begin(115200);
    delay(100);
    Wire.begin();
    Serial.println(F("Starting..."));
    if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
    Serial.println("OLED begun");
    display.display();
    delay(100);
    display.clearDisplay();
    display.display();
    display.setTextSize(1);
    display.setTextColor(SSD1306_WHITE);
    display.setRotation(0);
    Serial.println("Connecting to ");
    Serial.println(ssid);
    //Connect to your local wi-fi network
    WiFi.begin(ssid, password);
    //check wi-fi is connected to wi-fi network
    while (WiFi.status() != WL_CONNECTED) {
    delay(1000);
    Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected..!");
    Serial.print("Got IP: "); Serial.println(WiFi.localIP());
    server.on("/", handle_OnConnect);
    server.onNotFound(handle_NotFound);
    server.begin();
    Serial.println("HTTP server started");
    iaqSensor.begin(BME680_I2C_ADDR_SECONDARY, Wire);
    output = "\nBSEC library version " + String(iaqSensor.version.major) + "." + String(iaqSensor.version.minor) + "." + String(iaqSensor.version.major_bugfix) + "." + String(iaqSensor.version.minor_bugfix);
    Serial.println(output);
    checkIaqSensorStatus();
    bsec_virtual_sensor_t sensorList[10] = {
    BSEC_OUTPUT_RAW_TEMPERATURE,
    BSEC_OUTPUT_RAW_PRESSURE,
    BSEC_OUTPUT_RAW_HUMIDITY,
    BSEC_OUTPUT_RAW_GAS,
    BSEC_OUTPUT_IAQ,
    BSEC_OUTPUT_STATIC_IAQ,
    BSEC_OUTPUT_CO2_EQUIVALENT,
    iaqSensor.updateSubscription(sensorList, 10, BSEC_SAMPLE_RATE_LP);
    void loop() {
    // put your main code here, to run repeatedly
    server.handleClient();
    display.setCursor(0,0);
    unsigned long time_trigger = millis();
    if (iaqSensor.run()) { // If new data is available
    output = String(time_trigger);
    output += ", " + String(iaqSensor.rawTemperature);
    output += ", " + String(iaqSensor.pressure);
    output += ", " + String(iaqSensor.rawHumidity);
    output += ", " + String(iaqSensor.gasResistance);
    output += ", " + String(iaqSensor.iaq);
    output += ", " + String(iaqSensor.iaqAccuracy);
    output += ", " + String(iaqSensor.temperature);
    output += ", " + String(iaqSensor.humidity);
    output += ", " + String(iaqSensor.staticIaq);
    output += ", " + String(iaqSensor.co2Equivalent);
    output += ", " + String(iaqSensor.breathVocEquivalent);
    } else {
    Serial.print("Temperature = ");
    Serial.print(iaqSensor.temperature);
    Serial.println(" *C");
    display.print("Temperature: ");
    display.print(iaqSensor.temperature);
    display.println(" *C");
    Serial.print("Pressure = ");
    Serial.print(iaqSensor.pressure / 100.0);
    Serial.println(" hPa");
    display.print("Pressure: ");
    display.print(iaqSensor.pressure / 100);
    display.println(" hPa");
    Serial.print("Humidity = ");
    Serial.print(iaqSensor.humidity);
    Serial.println(" %");
    display.print("Humidity: ");
    display.print(iaqSensor.humidity);
    display.println(" %");
    Serial.print("IAQ = ");
    Serial.print(iaqSensor.staticIaq);
    Serial.println(" PPM");
    display.print("IAQ: ");
    display.print(iaqSensor.staticIaq);
    display.println(" PPM");
    Serial.print("CO2 equiv = ");
    Serial.print(iaqSensor.co2Equivalent);
    display.print("CO2eq: ");
    display.print(iaqSensor.co2Equivalent);
    Serial.print("Breath VOC = ");
    Serial.print(iaqSensor.breathVocEquivalent);
    display.print("VOC: ");
    display.print(iaqSensor.breathVocEquivalent);
    if ((iaqSensor.staticIaq > 0) && (iaqSensor.staticIaq <= 50)) {
    IAQsts = "Good";
    Serial.print("IAQ: Good");
    display.print("IAQ: Good");
    if ((iaqSensor.staticIaq > 51) && (iaqSensor.staticIaq <= 100)) {
    IAQsts = "Average";
    Serial.print("IAQ: Average");
    display.print("IAQ: Average");
    if ((iaqSensor.staticIaq > 101) && (iaqSensor.staticIaq <= 150)) {
    IAQsts = "Little Bad";
    Serial.print("IAQ: Little Bad");
    display.print("IAQ: Little Bad");
    if ((iaqSensor.staticIaq > 151) && (iaqSensor.staticIaq <= 200)) {
    IAQsts = "Bad";
    Serial.print("IAQ: Bad");
    display.print("IAQ: Bad");
    if ((iaqSensor.staticIaq > 201) && (iaqSensor.staticIaq <= 300)) {
    IAQsts = "Worse";
    Serial.print("IAQ: Worse");
    display.print("IAQ: Worse");
    if ((iaqSensor.staticIaq > 301) && (iaqSensor.staticIaq <= 500)) {
    IAQsts = "Very Bad";
    Serial.print("IAQ: Very Bad");
    display.print("IAQ: Very Bad");
    if ((iaqSensor.staticIaq > 500)){
    IAQsts = "Very Very Bad";
    Serial.print("IAQ: Very Very Bad");
    display.print("IAQ: Very Very Bad");
    Serial.println();
    display.display();
    delay(2000);
    // Helper function definitions
    if (iaqSensor.status != BSEC_OK) {
    if (iaqSensor.status < BSEC_OK) {
    output = "BSEC error code : " + String(iaqSensor.status);
    for (;;)
    errLeds(); /* Halt in case of failure */
    } else {
    output = "BSEC warning code : " + String(iaqSensor.status);
    if (iaqSensor.bme680Status != BME680_OK) {
    if (iaqSensor.bme680Status < BME680_OK) {
    output = "BME680 error code : " + String(iaqSensor.bme680Status);
    for (;;)
    } else {
    output = "BME680 warning code : " + String(iaqSensor.bme680Status);
    void handle_OnConnect() {
    temperature = iaqSensor.temperature;
    humidity = iaqSensor.humidity;
    pressure = iaqSensor.pressure / 100.0;
    IAQ = iaqSensor.staticIaq;
    carbon = iaqSensor.co2Equivalent;
    VOC = iaqSensor.breathVocEquivalent;
    server.send(200, "text/html", SendHTML(temperature, humidity, pressure, IAQ, carbon, VOC, IAQsts));
    void handle_NotFound() {
    server.send(404, "text/plain", "Not found");
    String SendHTML(float temperature, float humidity, float pressure, float IAQ, float carbon, float VOC, const char* IAQsts) {
    String html = "<!DOCTYPE html>";
    html += "<html>";
    html += "<head>";
    html += "<title>BME680 Webserver</title>";
    html += "<meta name='viewport' content='width=device-width, initial-scale=1.0'>";
    html += "<link rel='stylesheet' href='https://cdnjs.cloudflare.com/ajax/libs/font-awesome/5.7.2/css/all.min.css'>";
    html += "<link rel='stylesheet' type='text/css' href='styles.css'>";
    html += "<style>";
    html += "body { background-color: #fff; font-family: sans-serif; color: #333333; font: 12px Helvetica, sans-serif box-sizing: border-box;}";
    html += "#page { margin: 18px; background-color: #fff;}";
    html += ".container { height: inherit; padding-bottom: 18px;}";
    html += ".header { padding: 18px;}";
    html += ".header h1 { padding-bottom: 0.3em; color: #f4a201; font-size: 25px; font-weight: bold; font-family: Garmond, 'sans-serif'; text-align: center;}";
    html += "h2 { padding-bottom: 0.2em; border-bottom: 1px solid #eee; margin: 2px; text-align: center;}";
    html += ".box-full { padding: 18px; border 1px solid #ddd; border-radius: 1em 1em 1em 1em; box-shadow: 1px 7px 7px 1px rgba(0,0,0,0.4); background: #fff; margin: 18px; width: 300px;}";
    html += "@media (max-width: 494px) { #page { width: inherit; margin: 5px auto; } #content { padding: 1px;} .box-full { margin: 8px 8px 12px 8px; padding: 10px; width: inherit;; float: none; } }";
    html += "@media (min-width: 494px) and (max-width: 980px) { #page { width: 465px; margin 0 auto; } .box-full { width: 380px; } }";
    html += "@media (min-width: 980px) { #page { width: 930px; margin: auto; } }";
    html += ".sensor { margin: 10px 0px; font-size: 2.5rem;}";
    html += ".sensor-labels { font-size: 1rem; vertical-align: middle; padding-bottom: 15px;}";
    html += ".units { font-size: 1.2rem;}";
    html += "hr { height: 1px; color: #eee; background-color: #eee; border: none;}";
    html += "</style>";
    //Ajax Code Start
    html += "&lt;script&gt;\n";
    html += "setInterval(loadDoc,1000);\n";
    html += "function loadDoc() {\n";
    html += "var xhttp = new XMLHttpRequest();\n";
    html += "xhttp.onreadystatechange = function() {\n";
    html += "if (this.readyState == 4 && this.status == 200) {\n";
    html += "document.body.innerHTML =this.responseText}\n";
    html += "};\n";
    html += "xhttp.open(\"GET\", \"/\", true);\n";
    html += "xhttp.send();\n";
    html += "}\n";
    html += "&lt;/script&gt;\n";
    //Ajax Code END
    html += "</head>";
    html += "<body>";
    html += "<div id='page'>";
    html += "<div class='header'>";
    html += "<h1>BME680 IAQ Monitoring System</h1>";
    html += "</div>";
    html += "<div id='content' align='center'>";
    html += "<div class='box-full' align='left'>";
    html += "<h2>";
    html += "IAQ Status: ";
    html += IAQsts;
    html += "</h2>";
    html += "<div class='sensors-container'>";
    //For Temperature
    html += "<div class='sensors'>";
    html += "<p class='sensor'>";
    html += "<i class='fas fa-thermometer-half' style='color:#0275d8'></i>";
    html += "<span class='sensor-labels'> Temperature </span>";
    html += temperature;
    html += "<sup class='units'>掳C</sup>";
    html += "</p>";
    html += "<hr>";
    html += "</div>";
    //For Humidity
    html += "<i class='fas fa-tint' style='color:#0275d8'></i>";
    html += "<span class='sensor-labels'> Humidity </span>";
    html += humidity;
    html += "<sup class='units'>%</sup>";
    html += "</p>";
    html += "<hr>";
    //For Pressure
    html += "<i class='fas fa-tachometer-alt' style='color:#ff0040'></i>";
    html += "<span class='sensor-labels'> Pressure </span>";
    html += pressure;
    html += "<sup class='units'>hPa</sup>";
    html += "</p>";
    html += "<hr>";
    //For VOC IAQ
    html += "<i class='fab fa-cloudversify' style='color:#483d8b'></i>";
    html += "<span class='sensor-labels'> IAQ </span>";
    html += IAQ;
    html += "<sup class='units'>PPM</sup>";
    html += "</p>";
    html += "<hr>";
    //For C02 Equivalent
    html += "<i class='fas fa-smog' style='color:#35b22d'></i>";
    html += "<span class='sensor-labels'> Co2 Eq. </span>";
    html += carbon;
    html += "</p>";
    html += "<hr>";
    //For Breath VOC
    html += "<i class='fas fa-wind' style='color:#0275d8'></i>";
    html += "<span class='sensor-labels'> Breath VOC </span>";
    html += VOC;
    html += "</p>";
    html += "</div>";
    html += "</div>";
    html += "</div>";
    html += "</div>";
    html += "</div>";
    html += "</body>";
    html += "</html>";
    return html;
    void errLeds(void)
    pinMode(LED_BUILTIN, OUTPUT);
    digitalWrite(LED_BUILTIN, HIGH);
    delay(100);
    digitalWrite(LED_BUILTIN, LOW);
    delay(100);
    Hi ilcnet,
    This code we can't find the mistakes, you need to provide more codes, such as where is the functions of process_data(), run(), etc.
    Furthermore, give us a detailed video when after the accuracy is 3, please.
