    How to run the BMP3-Sensor-API examples?
    jbruenn
    I'm trying to get the BMP3 sensor API running on a Raspberry Pi 5 - unfortunatly without success. Please would you provide a foolproof guide what do I have to install and to configure at the RaspPi to run the read_sensor_data example.
    Thanks for your help
    Jörg
    Hi jbruenn,
    There is BMP3 sensor API & example code on Github https://github.com/boschsensortec/BMP3-Sensor-API
    We also upload BMP3 example code on STM32 for your reference.
    Hi @BSTRobin ,
    thank you for your answer. To be honest: I'm flashed. I dreamed of a much simpler example. Something like:
    #include <unistd.h> //Needed for I2C port
    #include <fcntl.h> //Needed for I2C port
    #include <sys/ioctl.h> //Needed for I2C port
    #include <linux/i2c-dev.h> //Needed for I2C port
    #include <stdio.h>
    int main(void)
    int file_i2c;
    int length;
    unsigned char buffer[60];
    for (int i = 0; i < 60; i++)
    buffer[i] = 0;
    //----- OPEN THE I2C BUS -----
    char *filename = "/dev/i2c-1";
    if ((file_i2c = open(filename, O_RDWR)) < 0)
    //ERROR HANDLING: you can check errno to see what went wrong
    printf("Failed to open the i2c bus");
    return -1;
    int addr = 0x77; //<<<<<The I2C address of the slave
    if (ioctl(file_i2c, I2C_SLAVE, addr) < 0)
    printf("Failed to acquire bus access and/or talk to slave.\n");
    //ERROR HANDLING; you can check errno to see what went wrong
    return -1;
    //----- READ BYTES -----
    length = 32; //<<< Number of bytes to read
    if (read(file_i2c, buffer, length) != length) //read() returns the number of bytes actually read, if it doesn't match then an error occurred (e.g. no response from the device)
    //ERROR HANDLING: i2c transaction failed
    printf("Failed to read from the i2c bus.\n");
    else
    printf("Data read: \n");
    for (int i = 0; i < length; i++)
    printf("0x%02X, ", buffer[i]);
    printf("\n");
    //----- WRITE BYTES -----
    /* buffer[0] = 0x01;
    buffer[1] = 0x02;
    length = 2; //<<< Number of bytes to write
    if (write(file_i2c, buffer, length) != length) //write() returns the number of bytes actually written, if it doesn't match then an error occurred (e.g. no response from the device)
    // ERROR HANDLING: i2c transaction failed
    printf("Failed to write to the i2c bus.\n");
    return 0;
    This code doesn't work:
    Data read:
    0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00,
    I tried to cherry-pick from your reference code. I failed: The common_porting.h includes stm32f4xx_hal.h. Do I really need another micro controller to get results from the sensor? I can't imagine ...
    Jörg
