    Microcontroller for application board 3.0
    Newguy
    Currently, I am running C. scripts similar to the one in the provided examples (quaternion or Euler for example). I run all of them by making a C file and using Makefile to make a .exe and run the sensors. I had assumed that everything is uploaded to the application board and it will output its prints through Data I/O pin when the application board is turned on. Is this true or does something need to be done to have the data output through Data I/O pin when the sensor is turned on?
    Hi Newguy,
    Do you mean you want to run the compiled program to the microcontroller instead of running *.exe?
    If yes, you can install Coines software and refer to the document "C:\COINES\v2.8.8\doc\BST-DHW-AN013\pdf".
    Run your program to RAM of microcontroller
    mingw32-make LOCATION=RAM TARGET=MCU_APP30 download
    Run your program to Flash of microcontroller
    mingw32-make LOCATION=FLASH TARGET=MCU_APP30 download
    It says the .elf file fail. How do I make it work?
    Hi Newguy,
    You can execute this command "mingw32-make LOCATION=FLASH TARGET=MCU_APP30 download" and try it again.
