    Unable to read acceleration of BMA456
    sat3_3
    I want to read only the raw sensor values, but it doesn't work. I'm using an 8-bit MCU, so I'd like to read data with the minimum configuration. It seems possible according to the topics below, but could you please tell me what I am missing?
    https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BMA456-without-configuration-file/td-p/5...
    chip_ID is being read correctly.
    #define BMA4_ACC_X_LOW                            UINT8_C(0x12)
    #define BMA4_ACC_X_HIGH                           UINT8_C(0x13)
    uint8_t data, status = 0;
    i2c_single_byte_write(BMA4_I2C_ADDR_PRIMARY, BMA4_POWER_CONF_ADDR, 0x00);
    delay_ms(1);
    i2c_single_byte_write(BMA4_I2C_ADDR_PRIMARY, BMA4_POWER_CTRL_ADDR, 0x04);
    delay_ms(500);
    status = i2c_single_byte_read(BMA4_I2C_ADDR_PRIMARY, BMA4_STATUS_ADDR); // read status = 0x90
    data = i2c_single_byte_read(BMA4_I2C_ADDR_PRIMARY, BMA4_ACC_X_LOW); // read data = 0x00
    Hi sat3_3,
    We conducted tests, BMA456 can read data from registers without loading configuration file.
    I have attached an example on STM32 32-bit MCU for your reference.
    void run_without_config_file(void)
    int8_t rslt;
    uint8_t reg_data, command_reg, status;
    uint8_t data[BMA4_ACCEL_DATA_LENGTH] = { 0 };
    uint16_t lsb = 0, msb = 0;
    int16_t x, y, z;
    uint8_t bma456_i2c_addr;
    bma456_i2c_addr = BMA4_I2C_ADDR_SECONDARY;
    SensorAPI_I2Cx_Read(BMA4_CHIP_ID_ADDR, &reg_data, 1, &bma456_i2c_addr);
    PDEBUG("Chip ID:0x%02x\r\n", reg_data);
    command_reg = 0xB6;
    SensorAPI_I2Cx_Write(BMA4_CMD_ADDR, &command_reg, 1, &bma456_i2c_addr);
    HAL_Delay(100);
    reg_data = 0;
    SensorAPI_I2Cx_Write(BMA4_POWER_CONF_ADDR, &reg_data, 1, &bma456_i2c_addr);
    bst_delay_us(450,NULL);
    reg_data = 0x04;
    SensorAPI_I2Cx_Write(BMA4_POWER_CTRL_ADDR, &reg_data, 1, &bma456_i2c_addr);
    bst_delay_us(2,NULL);
    SensorAPI_I2Cx_Read(BMA4_STATUS_ADDR, &reg_data, 1, &bma456_i2c_addr);
    PDEBUG("Status:0x%02x\r\n", reg_data);
    for(int i=0;i<100;i++)
    SensorAPI_I2Cx_Read(BMA4_DATA_8_ADDR, data, BMA4_ACCEL_DATA_LENGTH, &bma456_i2c_addr);
    msb = data[1];
    lsb = data[0];
    /* Accel data x axis */
    x = (int16_t)((msb << 😎 | lsb);
    msb = data[3];
    lsb = data[2];
    /* Accel data y axis */
    y = (int16_t)((msb << 😎 | lsb);
    msb = data[5];
    lsb = data[4];
    /* Accel data z axis */
    z = (int16_t)((msb << 😎 | lsb);
    PDEBUG("data X: %d, Y: %d, Z: %d\r\n", x, y, z);
    HAL_Delay(500);
    Hi BSTRobin,
    Thank you for your support.
    I tried implementing it based on the sample code you provided, but it didn't work. The sample code uses BMA4_I2C_ADDR_SECONDARY, but will it work with PRIMARY as well? I would like to receive any other advice.
    I suspected a malfunction and tried other chips, but the result was the same. I have attached the circuit diagram. Could you also check the problem with the circuit?
        int16_t x, y, z;
        int8_t addr = BMA4_I2C_ADDR_PRIMARY;
        reg_data = i2c_single_byte_read(addr, BMA4_CHIP_ID_ADDR);
        DebugPrint("CHIP ID: %x\r\n", reg_data);
        i2c_single_byte_write(addr , BMA4_CMD_ADDR, 0xB6);
        delay_ms(100);
        i2c_single_byte_write(addr , BMA4_POWER_CONF_ADDR, 0x00);
        delay_us(450);
        i2c_single_byte_write(addr , BMA4_POWER_CTRL_ADDR, 0x04);
        delay_us(2);
        reg_data = i2c_single_byte_read(addr, BMA4_STATUS_ADDR);
        DebugPrint("STATUS: %x\r\n", reg_data);
        delay_ms(500);
        while(1){
            data[0] = i2c_single_byte_read(addr, BMA4_ACC_X_LOW);
            data[1] = i2c_single_byte_read(addr, BMA4_ACC_X_HIGH);
            data[2] = i2c_single_byte_read(addr, BMA4_ACC_Y_LOW);
            data[3] = i2c_single_byte_read(addr, BMA4_ACC_Y_HIGH);
            data[4] = i2c_single_byte_read(addr, BMA4_ACC_Z_LOW);
            data[5] = i2c_single_byte_read(addr, BMA4_ACC_Z_HIGH);
            msb = data[1];
    	lsb = data[0];
    	x = (int16_t)((msb <<  | lsb);
    	msb = data[3];
    	lsb = data[2];
    	y = (int16_t)((msb <<  | lsb);
    	msb = data[5];
    	lsb = data[4];
    	z = (int16_t)((msb <<  | lsb);
    	DebugPrint("data X: %d, Y: %d, Z: %d\r\n", x, y, z);
    	delay_ms(500);
    image.pngschematicschematic
    There was a problem with the I2C library we were using. We fixed it and confirmed that BMA456 works properly.
