    BMG250 Zero-rate offset change over temperature
    We got two working PCBs with the BMG250 which measures a rotation on Z axis. It's data is processed on a MSP430 MCU. The datasheet at page 8 of the BMG250 states that the Zero-rate offset change over temperature is 0.05 °/s/K in a range between -40°C to +85°C. This implies that a positive temperature change results in a positive zero-rate offset change. But our two samples behave in opposite directions. While one offset is rising the other is decreasing. Is it a faulty entry in the datashet or can it be another problem?
    Re: BMG250 Zero-rate offset change over temperature
    Hi ,
    Here 0.05 °/s/K means +/-0.05 °/s/K.  and a positive temperature change may result in negative zero-rate offset change. Vice versus.
    Thank you for your reply. But it's difficult to work with this documentation. In fact, I had never to work with a data sheet which had so many flaws.
    @Unchipped
    We are constantly trying to improve our documentation. Free free to share your issues in these forums 👍
