07-14-2021 10:06 AM
I'm currently using BMX160 for my project. However, it is out of stock everywhere i seached for.
Is there any potential replacement? My piority is having same footprint and similar performance
Thank you in advance.
07-14-2021 11:26 AM
Hello t_an0410,
Please refer the following product selector guide.
https://www.bosch-sensortec.com/media/boschsensortec/downloads/promotion_material/product-selector-e...
You could consider BMI160 or BMI270 if you want to use same footprint and don't need magnetometer.
07-15-2021 10:03 AM
Thank you for your reply
Unfortunately, I also required the magnetometer.
I will look at the guide to see if I can find any thing. If you have any other suggestion please do tell me.
07-16-2021 04:27 AM
Hello t_an0410,
The recommended solution is to use BMI160 or BMI270 and external BMM150. Both BMI160 and BMI270 have a second interface, which can extend BMM150.
07-16-2021 08:31 AM
Thank you for your reply.
I just check BMM150 and apparently it is also out of stock.
Is there any other potential repacement? from the product guide, it seems that BMM150 is the only magnetometer
