07-05-2024 03:18 PM - edited 07-05-2024 04:48 PM
I am using the BME688 with the ESP32-S3 in the Espressif IDE (ESP-IDF), and I want to employ the BSEC library to obtain the IAQ.
First of all, I downloaded the BSEC version 2.5.0.2 library from Bosch Sensortec's website. However, I encountered a problem linking the BSEC library to my project. I found a potential solution on Bosch Sensortec's community forum, but I encountered several errors during the project compilation. How can I resolve these errors? Additionally, it seems that the libalgobsec.h file in the forum post is empty. Where is the libalgobsec.a file?. Could you advise me on what changes I should make in the CMake file or any other file, if necessary?
Thank you for your assistance.
Best regards.
07-21-2024 03:47 PM
Hi AmirTa,
Thank for your feedback.
As you used BME688, ESP32-S3 and had downloaded BSEC2.5 software, you should use the library "bsec_v2-5-0-2\algo\normal_version\bin\esp\esp32_s3\libalgobsec.a", and using the header files in folder "bsec_v2-5-0-2" will be enough. libalgobsec.h is not an official file in BSEC2.5.
07-29-2024 01:42 AM
Hello BSTRobin, i try change the libalgosec.a from the AmirTa but i have the same problem, actualy i use the IDF 5.2, and the problem is founded in the all archicteture from ESP32, Riscv and Xtensa.
Can you help us?
In attch the printscream from the error.
08-06-2024 12:40 PM
Hi BSTRobin,
Thank you for your reply.
I finally managed to add and compile the library into the project, but the bsec_iot_loop function does not produce any output!!!
How should I fix this?
(The bsec_iot_init function executes well, and there are no errors in bme68x_status or bsec_status)
