Hi Robin,
The same related to my Cortex-M33 platform, Other person have successfully implemented using your BSEC1 on BME680.
Please check the below thread:
Solved: temperature values is always 0 (bosch-sensortec.com)
Regards,
Kumar
Hello franciskumar200,
How come other person Mr. JimitP have suucess with old version with the source of "bsec_iot_example.c".
reply: "bsec_iot_example. C" is an example of bsec1. If bme680 is used, you can refer to it.
'Is this the library is compatible with the flags. "arm-none-eabi-gcc -mcpu=cortex-m33 -mthumb -mfpu=fpv5-sp-d16 -mfloat-abi=hard
Reply: There was platform and compiler support list, you could check it from the list.You can also use your compiler to try whether the compilation passes or not?
https://www.bosch-sensortec.com/media/boschsensortec/downloads/bsec/bsec1_binary_size_information.pd...
By the way, what sensor part you used? BME680, BME688?
Under what compiler do you want to compile?
Hi Robin,
Yes, I am using BME688 with "arm-none-eabi-gcc" compiler.
I am not clear with BEC2 calling in my main application, I understand the BEC1 algo to call the program with our i2c interface rae and write calls with reference code.
Do you have any application skide these values can convert in desktop software? I mean i amable to get the RAW values without using your BSEC algo. Can i apply your bsec algo from application end?
Regards,
Kumar
Hi Robin,
I tried with other libraries, but there are still some issues.
Is there any desktop standalone application which I can forward my GAS raw values to your BEC library? Will it give the GAS results?
For example i am getting RAW values for GAS = 856789 ohm. should i get the actual GAS index in ppm while i pass this value to your BEC lib.
Regards,
Kumar
Except for the software on the official website and GitHub, we have no other software.
