04-28-2022 11:14 PM
I'm noticing in my bmeraw files as well as my data output from a single BME688 sensor that while running different heater profiles with a duty cycle of 1:0 that I am seeing every so often the gas resistance value: 102400000.000000 on step index zero (and sometimes index 1). I don't believe this is normal as the previous values before it are much smaller. Is there any explaination for why this might be happening?
I have tried five different 8-sensor development kits and two seperate breakout boards with the BME688 and I still see this value output in my data when running with a duty cycle of 1:0. I am assuming this might be due to the profile transitioning so quickly from the last step index temperature back to the first, but I've also tested this using the default config that comes with the dev kits and see the same thing.
All of these sensors have undergone a 72hr burn-in period, but I am still wondering, do I need to allow the sensors to run 5 minutes before I can assume I am receiving genuine data?
Any insight into this anomaly would be greatly appreciated!
Also, here is some data so you can see what I am talking about:
Sensor 0:
Time since power-on | RTC Time in Seconds | Temp | Pressure | Rel. Humidity | Gas Resistance | HP Step Index | Scanning enabled | Heater Profile | Duty Cycle |
116009 | 1.65E+09 | 29.26295 | 999.9167 | 24.46373 | 102400000 | 0 | 1 | heater_301 | duty_1 |
121804 | 1.65E+09 | 28.66775 | 999.906 | 24.44672 | 84074408 | 1 | 1 | heater_301 | duty_1 |
122084 | 1.65E+09 | 28.90533 | 999.8544 | 24.49614 | 4751740 | 2 | 1 | heater_301 | duty_1 |
123980 | 1.65E+09 | 29.55556 | 999.9169 | 24.54941 | 4136329.25 | 3 | 1 | heater_301 | duty_1 |
125940 | 1.65E+09 | 29.71061 | 999.9347 | 24.45399 | 3925251.5 | 4 | 1 | heater_301 | duty_1 |
127900 | 1.65E+09 | 29.84066 | 999.9174 | 24.44756 | 3477817.75 | 5 | 1 | heater_301 | duty_1 |
128180 | 1.65E+09 | 29.98571 | 999.8882 | 24.35675 | 383880.0313 | 6 | 1 | heater_301 | duty_1 |
130140 | 1.65E+09 | 30.48339 | 999.888 | 24.24382 | 520589.7188 | 7 | 1 | heater_301 | duty_1 |
132100 | 1.65E+09 | 30.63845 | 999.9015 | 24.10568 | 579841.4375 | 8 | 1 | heater_301 | duty_1 |
133932 | 1.65E+09 | 30.75849 | 999.9071 | 23.84773 | 614277.125 | 9 | 0 | heater_301 | duty_1 |
134382 | 1.65E+09 | 30.16327 | 999.9437 | 23.73542 | 102400000 | 0 | 1 | heater_301 | duty_1 |
140114 | 1.65E+09 | 29.51054 | 999.9561 | 23.76816 | 94534440 | 1 | 1 | heater_301 | duty_1 |
140394 | 1.65E+09 | 29.76313 | 999.9347 | 23.79697 | 5160315 | 2 | 1 | heater_301 | duty_1 |
142354 | 1.65E+09 | 30.40336 | 999.9016 | 23.88054 | 4527217.5 | 3 | 1 | heater_301 | duty_1 |
144314 | 1.65E+09 | 30.53841 | 999.8973 | 23.86371 | 4074608.25 | 4 | 1 | heater_301 | duty_1 |
146274 | 1.65E+09 | 30.65095 | 999.9001 | 23.67485 | 3757798.25 | 5 | 1 | heater_301 | duty_1 |
146554 | 1.65E+09 | 30.791 | 999.9001 | 23.73821 | 406268.5938 | 6 | 1 | heater_301 | duty_1 |
148374 | 1.65E+09 | 31.29619 | 999.9119 | 23.57239 | 548620.4375 | 7 | 1 | heater_301 | duty_1 |
150334 | 1.65E+09 | 31.48126 | 999.9209 | 23.38349 | 603417.8125 | 8 | 1 | heater_301 | duty_1 |
152306 | 1.65E+09 | 31.6013 | 999.9225 | 23.19007 | 642610.625 | 9 | 0 | heater_301 | duty_1 |
152750 | 1.65E+09 | 30.99358 | 999.8925 | 23.22111 | 102400000 | 0 | 1 | heater_301 | duty_1 |
158452 | 1.65E+09 | 30.28081 | 999.8987 | 23.10701 | 102400000 | 1 | 1 | heater_301 | duty_1 |
158732 | 1.65E+09 | 30.54591 | 999.8482 | 23.16282 | 5639931 | 2 | 1 | heater_301 | duty_1 |
160692 | 1.65E+09 | 31.21866 | 999.8992 | 23.25308 | 4760023 | 3 | 1 | heater_301 | duty_1 |
162652 | 1.65E+09 | 31.36121 | 999.9281 | 23.15172 | 4289005 | 4 | 1 | heater_301 | duty_1 |
164612 | 1.65E+09 | 31.44874 | 999.9263 | 23.03589 | 3902810.75 | 5 | 1 | heater_301 | duty_1 |
164892 | 1.65E+09 | 31.5888 | 999.8988 | 22.92911 | 419758.1563 | 6 | 1 | heater_301 | duty_1 |
166712 | 1.65E+09 | 32.07648 | 999.9006 | 22.92118 | 566841.9375 | 7 | 1 | heater_301 | duty_1 |
168672 | 1.65E+09 | 32.25155 | 999.8891 | 22.74788 | 629572.6875 | 8 | 1 | heater_301 | duty_1 |
170726 | 1.65E+09 | 32.3966 | 999.9071 | 22.66266 | 661926.3125 | 9 | 0 | heater_301 | duty_1 |
171028 | 1.65E+09 | 31.73385 | 999.9297 | 22.46285 | 102400000 | 0 | 1 | heater_301 | duty_1 |
176824 | 1.65E+09 | 31.04359 | 999.8773 | 22.51532 | 102400000 | 1 | 1 | heater_301 | duty_1 |
177106 | 1.65E+09 | 31.31369 | 999.9058 | 22.5552 | 5734686.5 | 2 | 1 | heater_301 | duty_1 |
179077 | 1.65E+09 | 31.97894 | 999.9767 | 22.62806 | 4870392.5 | 3 | 1 | heater_301 | duty_1 |
180910 | 1.65E+09 | 32.124 | 999.9371 | 22.56409 | 4367902 | 4 | 1 | heater_301 | duty_1 |
182870 | 1.65E+09 | 32.23154 | 999.9473 | 22.45517 | 3991230.25 | 5 | 1 | heater_301 | duty_1 |
183150 | 1.65E+09 | 32.37159 | 999.9283 | 22.44376 | 428451.875 | 6 | 1 | heater_301 | duty_1 |
185111 | 1.65E+09 | 32.86929 | 999.9265 | 22.35142 | 576901.4375 | 7 | 1 | heater_301 | duty_1 |
187106 | 1.65E+09 | 33.02935 | 999.9626 | 22.16148 | 641403.0625 | 8 | 1 | heater_301 | duty_1 |
189092 | 1.65E+09 | 33.14439 | 999.9391 | 21.9686 | 678370.3125 | 9 | 0 | heater_301 | duty_1 |
189546 | 1.65E+09 | 32.40911 | 999.9216 | 21.95513 | 102400000 | 0 | 1 | heater_301 | duty_1 |
195227 | 1.65E+09 | 31.80138 | 999.9281 | 21.9716 | 102400000 | 1 | 1 | heater_301 | duty_1 |
195368 | 1.65E+09 | 32.07148 | 999.9323 | 21.92154 | 5734686.5 | 2 | 1 | heater_301 | duty_1 |
197328 | 1.65E+09 | 32.72173 | 999.9356 | 22.0874 | 4879094.5 | 3 | 1 | heater_301 | duty_1 |
199300 | 1.65E+09 | 32.84678 | 999.9012 | 22.00623 | 4396029 | 4 | 1 | heater_301 | duty_1 |
201261 | 1.65E+09 | 32.95432 | 999.931 | 21.87639 | 4245659.5 | 5 | 1 | heater_301 | duty_1 |
201541 | 1.65E+09 | 33.09938 | 999.9231 | 21.87577 | 426844.5313 | 6 | 1 | heater_301 | duty_1 |
203563 | 1.65E+09 | 33.60708 | 999.9446 | 21.76272 | 578367.6875 | 7 | 1 | heater_301 | duty_1 |
205387 | 1.65E+09 | 33.76964 | 999.9698 | 21.67355 | 652437.0625 | 8 | 1 | heater_301 | duty_1 |
207372 | 1.65E+09 | 33.88219 | 999.9709 | 21.45971 | 690026.9375 | 9 | 0 | heater_301 | duty_1 |
207812 | 1.65E+09 | 33.25694 | 999.9443 | 21.34916 | 102400000 | 0 | 1 | heater_301 | duty_1 |
213453 | 1.65E+09 | 32.50665 | 999.9229 | 21.4565 | 102400000 | 1 | 1 | heater_301 | duty_1 |
213757 | 1.65E+09 | 32.77175 | 999.8948 | 21.40598 | 5914801.5 | 2 | 1 | heater_301 | duty_1 |
215717 | 1.65E+09 | 33.44952 | 999.9363 | 21.6043 | 5018070.5 | 3 | 1 | heater_301 | duty_1 |
217677 | 1.65E+09 | 33.56956 | 999.9498 | 21.49652 | 4542279 | 4 | 1 | heater_301 | duty_1 |
219640 | 1.65E+09 | 33.6621 | 999.9875 | 21.39219 | 4142604.25 | 5 | 1 | heater_301 | duty_1 |
219960 | 1.65E+09 | 33.80966 | 999.9814 | 21.4074 | 435559.3438 | 6 | 1 | heater_301 | duty_1 |
221781 | 1.65E+09 | 34.29736 | 999.9784 | 21.32441 | 590371.875 | 7 | 1 | heater_301 | duty_1 |
223744 | 1.65E+09 | 34.46743 | 999.9862 | 21.11467 | 660006.4375 | 8 | 1 | heater_301 | duty_1 |
225728 | 1.65E+09 | 34.59248 | 999.9598 | 20.94943 | 702091.1875 | 9 | 0 | heater_301 | duty_1 |
226154 | 1.65E+09 | 33.97222 | 999.983 | 20.84532 | 102400000 | 0 | 1 | heater_301 | duty_1 |
231801 | 1.65E+09 | 33.1744 | 999.906 | 20.96571 | 102400000 | 1 | 1 | heater_301 | duty_1 |
232081 | 1.65E+09 | 33.43201 | 999.9029 | 21.0142 | 6056931.5 | 2 | 1 | heater_301 | duty_1 |
234041 | 1.65E+09 | 34.12228 | 999.95 | 21.08634 | 5107232 | 3 | 1 | heater_301 | duty_1 |
236001 | 1.65E+09 | 34.26734 | 999.9576 | 21.01716 | 4611314.5 | 4 | 1 | heater_301 | duty_1 |
237903 | 1.65E+09 | 34.35738 | 999.9641 | 20.91805 | 4136329.25 | 5 | 1 | heater_301 | duty_1 |
238184 | 1.65E+09 | 34.50244 | 999.921 | 20.9014 | 437233.125 | 6 | 1 | heater_301 | duty_1 |
240144 | 1.65E+09 | 34.99014 | 999.9292 | 20.81813 | 600762.6875 | 7 | 1 | heater_301 | duty_1 |
242103 | 1.65E+09 | 35.1427 | 999.9446 | 20.63906 | 673684.1875 | 8 | 1 | heater_301 | duty_1 |
244088 | 1.65E+09 | 35.25275 | 999.9229 | 20.48881 | 709386.9375 | 9 | 0 | heater_301 | duty_1 |
244532 | 1.65E+09 | 34.61999 | 999.9406 | 20.38989 | 102400000 | 0 | 1 | heater_301 | duty_1 |
250151 | 1.65E+09 | 33.84967 | 999.9334 | 20.55437 | 102400000 | 1 | 1 | heater_301 | duty_1 |
250445 | 1.65E+09 | 34.11728 | 999.9347 | 20.58229 | 6114573.5 | 2 | 1 | heater_301 | duty_1 |
252433 | 1.65E+09 | 34.77505 | 999.9386 | 20.71984 | 5184810 | 3 | 1 | heater_301 | duty_1 |
254436 | 1.65E+09 | 34.9051 | 999.9671 | 20.59194 | 4588070.5 | 4 | 1 | heater_301 | duty_1 |
256257 | 1.65E+09 | 35.00264 | 999.9599 | 20.48818 | 4174267.5 | 5 | 1 | heater_301 | duty_1 |
256537 | 1.65E+09 | 35.1452 | 999.9069 | 20.49226 | 437513.3438 | 6 | 1 | heater_301 | duty_1 |
258496 | 1.65E+09 | 35.65041 | 999.9525 | 20.36266 | 604486.4375 | 7 | 1 | heater_301 | duty_1 |
260457 | 1.65E+09 | 35.79798 | 999.9559 | 20.22542 | 669718.75 | 8 | 1 | heater_301 | duty_1 |
262449 | 1.65E+09 | 35.90052 | 999.9582 | 20.05914 | 708650.5 | 9 | 0 | heater_301 | duty_1 |
262886 | 1.65E+09 | 35.27526 | 999.9644 | 19.97709 | 102400000 | 0 | 1 | heater_301 | duty_1 |
268544 | 1.65E+09 | 34.45492 | 999.9391 | 20.12302 | 102400000 | 1 | 1 | heater_301 | duty_1 |
268823 | 1.65E+09 | 34.71753 | 999.9226 | 20.13989 | 6121427 | 2 | 1 | heater_301 | duty_1 |
270810 | 1.65E+09 | 35.42782 | 999.9488 | 20.20665 | 5116802 | 3 | 1 | heater_301 | duty_1 |
272770 | 1.65E+09 | 35.54537 | 999.968 | 20.10953 | 4706693.5 | 4 | 1 | heater_301 | duty_1 |
274729 | 1.65E+09 | 35.6179 | 999.9858 | 19.96768 | 4152052.75 | 5 | 1 | heater_301 | duty_1 |
275010 | 1.65E+09 | 35.76296 | 999.9381 | 20.03456 | 437793.9375 | 6 | 1 | heater_301 | duty_1 |
276969 | 1.65E+09 | 36.25067 | 999.9799 | 19.90888 | 595521.9375 | 7 | 1 | heater_301 | duty_1 |
278790 | 1.65E+09 | 36.41824 | 999.9913 | 19.74168 | 667753.5 | 8 | 1 | heater_301 | duty_1 |
280775 | 1.65E+09 | 36.53079 | 999.982 | 19.57631 | 718344.4375 | 9 | 0 | heater_301 | duty_1 |
281202 | 1.65E+09 | 35.88802 | 999.9655 | 19.4731 | 102400000 | 0 | 1 | heater_301 | duty_1 |
286911 | 1.65E+09 | 35.05517 | 999.9478 | 19.65521 | 102400000 | 1 | 1 | heater_301 | duty_1 |
287190 | 1.65E+09 | 35.31527 | 999.8976 | 19.70814 | 6152459.5 | 2 | 1 | heater_301 | duty_1 |
289151 | 1.65E+09 | 36.01057 | 999.9725 | 19.76274 | 5112012.5 | 3 | 1 | heater_301 | duty_1 |
291111 | 1.65E+09 | 36.13062 | 999.968 | 19.68154 | 4580374.5 | 4 | 1 | heater_301 | duty_1 |
293072 | 1.65E+09 | 36.22316 | 999.9904 | 19.59339 | 4111417.75 | 5 | 1 | heater_301 | duty_1 |
293351 | 1.65E+09 | 36.36572 | 999.9728 | 19.59197 | 438637.8125 | 6 | 1 | heater_301 | duty_1 |
295311 | 1.65E+09 | 36.85343 | 999.9716 | 19.49745 | 589861.75 | 7 | 1 | heater_301 | duty_1 |
297271 | 1.65E+09 | 36.98349 | 999.9554 | 19.32804 | 670376.4375 | 8 | 1 | heater_301 | duty_1 |
299117 | 1.65E+09 | 37.09353 | 999.958 | 19.19403 | 715333.5625 | 9 | 0 | heater_301 | duty_1 |
299623 | 1.65E+09 | 36.45826 | 1000.01 | 19.09717 | 102400000 | 0 | 1 | heater_301 | duty_1 |
305223 | 1.65E+09 | 35.44783 | 999.9228 | 18.43421 | 102400000 | 1 | 1 | heater_301 | duty_1 |
305503 | 1.65E+09 | 35.71544 | 999.913 | 18.42436 | 6135180.5 | 2 | 1 | heater_301 | duty_1 |
307464 | 1.65E+09 | 36.37322 | 999.994 | 18.11216 | 5259711 | 3 | 1 | heater_301 | duty_1 |
309446 | 1.65E+09 | 36.47076 | 999.9824 | 17.71054 | 4670467.5 | 4 | 1 | heater_301 | duty_1 |
311413 | 1.65E+09 | 36.5483 | 1000.021 | 17.37048 | 4242361.5 | 5 | 1 | heater_301 | duty_1 |
311694 | 1.65E+09 | 36.68086 | 999.9979 | 17.33181 | 451101.3125 | 6 | 1 | heater_301 | duty_1 |
313665 | 1.65E+09 | 37.16607 | 999.9792 | 17.04103 | 627835.6875 | 7 | 1 | heater_301 | duty_1 |
315588 | 1.65E+09 | 37.27361 | 999.9926 | 16.84199 | 711605.3125 | 8 | 1 | heater_301 | duty_1 |
317574 | 1.65E+09 | 37.35365 | 1000.007 | 16.48828 | 759643.9375 | 9 | 0 | heater_301 | duty_1 |
318013 | 1.65E+09 | 36.69086 | 1000.027 | 16.30949 | 102400000 | 0 | 1 | heater_301 | duty_1 |
323650 | 1.65E+09 | 35.84049 | 999.9459 | 16.20797 | 102400000 | 1 | 1 | heater_301 | duty_1 |
323930 | 1.65E+09 | 36.12061 | 999.9647 | 16.23817 | 6757682 | 2 | 1 | heater_301 | duty_1 |
325916 | 1.65E+09 | 36.7784 | 999.9827 | 16.24799 | 5675095.5 | 3 | 1 | heater_301 | duty_1 |
327770 | 1.65E+09 | 36.87844 | 999.9496 | 16.13119 | 5145728.5 | 4 | 1 | heater_301 | duty_1 |
329730 | 1.65E+09 | 36.94597 | 999.9828 | 16.00764 | 4607424 | 5 | 1 | heater_301 | duty_1 |
330010 | 1.65E+09 | 37.08853 | 999.9702 | 16.06607 | 469401.7813 | 6 | 1 | heater_301 | duty_1 |
331944 | 1.65E+09 | 37.57124 | 999.9794 | 15.91363 | 646873 | 7 | 1 | heater_301 | duty_1 |
333904 | 1.65E+09 | 37.6988 | 999.9933 | 15.73728 | 736161.0625 | 8 | 1 | heater_301 | duty_1 |
335890 | 1.65E+09 | 37.78634 | 999.9817 | 15.57422 | 777820 | 9 | 0 | heater_301 | duty_1 |
336327 | 1.65E+09 | 37.14856 | 1000.011 | 15.48542 | 102400000 | 0 | 1 | heater_301 | duty_1 |
341946 | 1.65E+09 | 36.26318 | 999.9908 | 15.57136 | 102400000 | 1 | 1 | heater_301 | duty_1 |
342226 | 1.65E+09 | 36.54079 | 999.9926 | 15.45417 | 7000213.5 | 2 | 1 | heater_301 | duty_1 |
344210 | 1.65E+09 | 37.20608 | 999.9939 | 15.63031 | 5795543 | 3 | 1 | heater_301 | duty_1 |
346182 | 1.65E+09 | 37.31113 | 1000.012 | 15.53942 | 5204574.5 | 4 | 1 | heater_301 | duty_1 |
348182 | 1.65E+09 | 37.37366 | 1000.006 | 15.46156 | 4710753.5 | 5 | 1 | heater_301 | duty_1 |
348462 | 1.65E+09 | 37.51622 | 999.9717 | 15.33719 | 471346.375 | 6 | 1 | heater_301 | duty_1 |
350282 | 1.65E+09 | 37.97892 | 999.9919 | 15.35586 | 651192.375 | 7 | 1 | heater_301 | duty_1 |
352243 | 1.65E+09 | 38.10148 | 1000.005 | 15.22529 | 741760.25 | 8 | 1 | heater_301 | duty_1 |
354228 | 1.65E+09 | 38.19152 | 1000.017 | 15.10326 | 784975.0625 | 9 | 0 | heater_301 | duty_1 |
354683 | 1.65E+09 | 37.55124 | 1000.006 | 15.02543 | 102400000 | 0 | 1 | heater_301 | duty_1 |
360427 | 1.65E+09 | 36.66085 | 1000.008 | 15.12701 | 102400000 | 1 | 1 | heater_301 | duty_1 |
360706 | 1.65E+09 | 36.94347 | 999.9789 | 15.16144 | 7004703 | 2 | 1 | heater_301 | duty_1 |
362565 | 1.65E+09 | 37.59876 | 1000.027 | 15.24017 | 5870297.5 | 3 | 1 | heater_301 | duty_1 |
364538 | 1.65E+09 | 37.70631 | 1000.032 | 15.18492 | 5150581.5 | 4 | 1 | heater_301 | duty_1 |
366526 | 1.65E+09 | 37.77884 | 1000.048 | 15.11778 | 4282279 | 5 | 1 | heater_301 | duty_1 |
366805 | 1.65E+09 | 37.9239 | 1000.033 | 15.21624 | 428990.375 | 6 | 1 | heater_301 | duty_1 |
368766 | 1.65E+09 | 38.39161 | 1000.064 | 15.04251 | 463978.25 | 7 | 1 | heater_301 | duty_1 |
370725 | 1.65E+09 | 38.50916 | 1000.091 | 14.91179 | 445507.9375 | 8 | 1 | heater_301 | duty_1 |
372571 | 1.65E+09 | 38.5892 | 1000.1 | 14.78432 | 422878.375 | 9 | 0 | heater_301 | duty_1 |
373010 | 1.65E+09 | 37.94641 | 1000.082 | 14.69186 | 66483388 | 0 | 1 | heater_301 | duty_1 |
378779 | 1.65E+09 | 37.07352 | 1000.035 | 14.78982 | 46761328 | 1 | 1 | heater_301 | duty_1 |
378963 | 1.65E+09 | 37.32864 | 1000.013 | 14.80244 | 2718884.75 | 2 | 1 | heater_301 | duty_1 |
380935 | 1.65E+09 | 37.99143 | 1000.053 | 14.87576 | 1854652.5 | 3 | 1 | heater_301 | duty_1 |
382909 | 1.65E+09 | 38.09398 | 1000.062 | 14.79503 | 1472322.125 | 4 | 1 | heater_301 | duty_1 |
384898 | 1.65E+09 | 38.1465 | 1000.069 | 14.6513 | 1217598.125 | 5 | 1 | heater_301 | duty_1 |
385179 | 1.65E+09 | 38.29407 | 1000.06 | 14.69895 | 195121.9531 | 6 | 1 | heater_301 | duty_1 |
387139 | 1.65E+09 | 38.77929 | 1000.091 | 14.57652 | 263713.625 | 7 | 1 | heater_301 | duty_1 |
389098 | 1.65E+09 | 38.90434 | 1000.087 | 14.45144 | 271258.2813 | 8 | 1 | heater_301 | duty_1 |
390943 | 1.65E+09 | 38.97688 | 1000.086 | 14.28858 | 272557.9063 | 9 | 0 | heater_301 | duty_1 |
06-24-2022 10:47 PM
06-25-2022 02:39 AM
06-28-2022 07:53 PM
Hi ilcnet,
Yes, 72 hours continuously is how I burned in my devkits. As for the state saving, check out the Arduino sketch, "basic_config.ino", that comes with the BSEC2 library. You can see in one of the functions that the state is saved off to the EEPROM, and there is a check to update it every so often (as defined in the code). For doing this outside of an Arduino MCU I am not too sure, but I am sure you can save the data to a file and read from it at sensor startup for the same effect.
After calibrating/burning-in the sensor with a state file in place you should be able to see a change in the output provided by your sensor (however no guarantee. I just work with the sensor and don't know nearly as much as the team in Bosch SensorTec that designed it).
06-30-2022 11:51 AM
07-04-2022 09:02 AM
Hi ilcnet,
For your previous feedback: I used this code for Bme688 but when sensor sense the smoke co2 and dirty weather the values going down.at the first co2 value is 500 and iaq value is 25 a few minutes later the values are stable in 530 and 30 and this is normal but when i burn a paper or spray a ethanol in front of sensor the values start to going down!
Can you describe your operation in detail? And record the print data. If there is a video, it is better.
